coq-club - [Coq-Club] Tip&trick: getting a Coq-able OCaml toplevel from Emacs
  • From: Gabriel Scherer <gabriel.scherer AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Tip&trick: getting a Coq-able OCaml toplevel from Emacs
  • Date: Wed, 24 Jun 2015 16:59:27 +0200
Hi coq-club,
During the Coq Coding Sprint, Thomas Sibut-Pinote asked for a way to
start an ocaml toplevel (from the Emacs buffer showing OCaml code of a
Coq plugin) that would already know about Coq library and internal
modules.
You probably already know that you can get an OCaml-able toplevel from
coqtop using the "Drop." command,
$ coqtop.byte
Welcome to Coq 8.4pl5 (November 2014)
Coq < Drop.
OCaml version 4.02.2
Camlp5 parsing version 6.13
# #use "include";;
The point of this mail is to let know this from Emacs (using caml-mode
or tuareg-mode):
- use whatever command your emacs-ocaml-mode uses to launch a toplevel
(Tuareg: C-x C-e)
- ask for "coqtop.byte" as a toplevel name
- run the command "Drop. Drop. ;;"
- then #use "include";; as usual
(Yes, you need two commands instead of just Drop., and you need the
two semicolons; this is the trick, found by Jacques-Henri Jourdan.)
