coq-club - [Coq-Club] induction with eqn:
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] induction with eqn:
  • Date: Fri, 26 Jun 2015 14:28:31 +1000
Hi all,
I discovered coq recently and have been enjoying myself doing some proofs with it, and seeing how "readable" I can make the proof scripts -- by which I mean making it so that you don't have to remember/imagine much of the state of the proof, rather you can just read it. One part of that, I think, is explicitly indicating what case is being examined when splitting the proof up into parts. So I want to be able to write:
  Variable P : nat -> Prop.
  Axiom P0: P 0.
  Axiom PSn : forall n, P n -> P (S n).
  Theorem Pn_1: forall n:nat, P n.
  Proof.
    induction n as [|n'].
    - Case (n = 0).
      apply P0.
    - Case (n = S n').
      apply PSn. exact IHn'.
  Qed.
​Unfortunately 'induction' doesn't keep 'n' around or introduce an hypothesis deconstructing n; and if I use induction eqn: H, then "n = ..." becomes part of the inductive hypothesis making it unusable. ​I asked on stackoverflow about this [0] and got pointed at a thread from september last year [1], which indicated induction/eqn: is just broken.
But then I had an inspiration -- when doing induction on n, the goal must P(n) for some function P : type(n) -> Prop; and after doing induction, the goal will be P(x) instead, and I can create an hypothesis "n = x" after the induction. And that seems to work:
(* like set (a:=b) except introduces a name and hypothesis *)
Tactic Notation "provide_name" ident(n) "=" constr(v)
       "as" simple_intropattern(H) :=
    assert (exists n, n = v) as [n H] by (exists v; reflexivity).
Tactic Notation
  "induction_eqn" ident(n) "as" simple_intropattern(HNS)
    "eqn:" ident(Hn) :=
  let PROP := fresh in (
    match goal with [ |- ?FP n ] => set ( PROP := FP ) end;
    induction n as HNS;
    match goal with [ |- PROP ?nnn ] => provide_name n = nnn as Hn end;
    unfold PROP in *; clear PROP
Tactic Notation "Case" constr(prop) :=
  lazymatch goal with
   | [ H: prop |- _ ] => idtac
   | _ => fail "looking at a different case than" prop
  end.
Theorem Pn_2: forall n:nat, P n.
Proof.
  intros n.
  induction_eqn n as [|n'] eqn: Hn.
  - Case (n = 0).
    apply P0.
  - Case (n = S n').
Qed.
Does that seem like a reasonable approach? Could "induction .. eqn:" be made to use that approach and actually work right? Or is it going to fail for more complicated types/induction rules, or more complicated propositions or similar?
Cheers,
aj
Anthony Towns <aj AT erisian.com.au>
