- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] induction with eqn:
- Date: Fri, 26 Jun 2015 12:00:31 +0200
Hi,
There are two different features IMHO here:
1) Document the different cases of a proof (see B. Pierce solution here: http://www.cis.upenn.edu/~bcpierce/sf/current/Induction.html#lab38), and:
1bis) if possible make coq verify this documentation in order to help writing correct doc (Pierce's solution does not this). This is a frequent wish and not currently implemented yet AFAIK.
2) Really generate equalities in the goal and the proof term which is iseful in some cases but not a good way to implement 1) IMHO as it "pollutes" the proof term and environment with (often useless) equalities.
The challenge is: implement 1bis) without 2).
Remarks on your tactic:
match goal with ?FP n =>...
will only match goals of this form. Doing "pattern n" before will capture a lot more goals.
Moreover it is not clear to me if the part
match goal with [ |- PROP ?nnn ] => ...
will not capture unwanted hypothesis.
Best,
P.
2015-06-26 6:28 GMT+02:00 Anthony Towns <aj AT erisian.com.au>:
Hi all,I discovered coq recently and have been enjoying myself doing some proofs with it, and seeing how "readable" I can make the proof scripts -- by which I mean making it so that you don't have to remember/imagine much of the state of the proof, rather you can just read it. One part of that, I think, is explicitly indicating what case is being examined when splitting the proof up into parts. So I want to be able to write:Variable P : nat -> Prop.Axiom P0: P 0.Axiom PSn : forall n, P n -> P (S n).Theorem Pn_1: forall n:nat, P n.Proof.induction n as [|n'].- Case (n = 0).apply P0.- Case (n = S n').apply PSn. exact IHn'.Qed.Unfortunately 'induction' doesn't keep 'n' around or introduce an hypothesis deconstructing n; and if I use induction eqn: H, then "n = ..." becomes part of the inductive hypothesis making it unusable. I asked on stackoverflow about this [0] and got pointed at a thread from september last year [1], which indicated induction/eqn: is just broken.But then I had an inspiration -- when doing induction on n, the goal must P(n) for some function P : type(n) -> Prop; and after doing induction, the goal will be P(x) instead, and I can create an hypothesis "n = x" after the induction. And that seems to work:(* like set (a:=b) except introduces a name and hypothesis *)Tactic Notation "provide_name" ident(n) "=" constr(v)"as" simple_intropattern(H) :=assert (exists n, n = v) as [n H] by (exists v; reflexivity).Tactic Notation"induction_eqn" ident(n) "as" simple_intropattern(HNS)"eqn:" ident(Hn) :=let PROP := fresh in (match goal with [ |- ?FP n ] => set ( PROP := FP ) end;induction n as HNS;match goal with [ |- PROP ?nnn ] => provide_name n = nnn as Hn end;unfold PROP in *; clear PROP).Tactic Notation "Case" constr(prop) :=lazymatch goal with| [ H: prop |- _ ] => idtac| _ => fail "looking at a different case than" propend.Theorem Pn_2: forall n:nat, P n.Proof.intros n.induction_eqn n as [|n'] eqn: Hn.- Case (n = 0).apply P0.- Case (n = S n').apply PSn. exact IHn'.Qed.Does that seem like a reasonable approach? Could "induction .. eqn:" be made to use that approach and actually work right? Or is it going to fail for more complicated types/induction rules, or more complicated propositions or similar?Cheers,aj--Anthony Towns <aj AT erisian.com.au>
- [Coq-Club] induction with eqn:, Anthony Towns, 06/26/2015
- Re: [Coq-Club] induction with eqn:, Pierre Courtieu, 06/26/2015
- Re: [Coq-Club] induction with eqn:, Anthony Towns, 06/27/2015
- RE: [Coq-Club] induction with eqn:, Soegtrop, Michael, 06/29/2015
