- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Printing a structured representation of a Prop?
- Date: Tue, 30 Jun 2015 12:24:59 +0000
Can you just disable notation? (Unset Printing Notations, or the View menu in CoqIDE). If you're using Check you might have to re-run the command after disabling.
As far as launching coqtop with ideslave in trunk, this works for me but I don't understand the new async proofs protocol (I picked the control channel port randomly):
coqtop -main-channel stdfds -control-channel 127.0.0.1:60875 -ideslave -async-proofs on
I would also like to hear more generally how to understand the XML protocol.
-Tej
On Tue, Jun 30, 2015 at 4:01 AM Clément Pit--Claudel <clement.pit AT gmail.com> wrote:
Hi all,
Is there a way to print a structured representation of a lemma's statement in Coq? Ideally I'd like to get something like (forall ((A type) (x A) (y A)) (impl (eq x y) (eq y x))) given the lemma [forall A (x y: A), x = y -> y = x].
* Basic extracting to JSON doesn't do, because Props are erased before extraction.
* The PrintAst XML command looks promising, but I'm not sure what its syntax is. [1]
* The code in texmacspp.ml also looks promising, but I have no idea how to call into it.
Thanks!
[1] More generally, I'm not sure how to invoke the IDE slave mode in trunk: the following command works with 8.4pl2, but on trunk it prints "Fatal error: ideslave communication channels not set.":
coqtop -ideslave <<< '<call val="mkcases">nat</call>'
- [Coq-Club] Printing a structured representation of a Prop?, Clément Pit--Claudel, 06/30/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Tej Chajed, 06/30/2015
