- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Printing a structured representation of a Prop?
- Date: Tue, 30 Jun 2015 01:01:29 -0700
Hi all,
Is there a way to print a structured representation of a lemma's statement in
Coq? Ideally I'd like to get something like (forall ((A type) (x A) (y A))
(impl (eq x y) (eq y x))) given the lemma [forall A (x y: A), x = y -> y = x].
* Basic extracting to JSON doesn't do, because Props are erased before
extraction.
* The PrintAst XML command looks promising, but I'm not sure what its syntax
is. [1]
* The code in texmacspp.ml also looks promising, but I have no idea how to
call into it.
Thanks!
[1] More generally, I'm not sure how to invoke the IDE slave mode in trunk:
the following command works with 8.4pl2, but on trunk it prints "Fatal error:
ideslave communication channels not set.":
coqtop -ideslave <<< '<call val="mkcases">nat</call>'
- [Coq-Club] Printing a structured representation of a Prop?, Clément Pit--Claudel, 06/30/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Tej Chajed, 06/30/2015
