coq-club - Re: [Coq-Club] Printing a structured representation of a Prop?
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Printing a structured representation of a Prop?
  • Date: Tue, 30 Jun 2015 20:34:59 -0700
On 06/30/2015 05:24 AM, Tej Chajed wrote:
> Can you just disable notation? (Unset Printing Notations, or the View menu
> in CoqIDE). If you're using Check you might have to re-run the command
> after disabling.
That not enough for my purposes; ideally, I don't want to be doing any
parsing myself; the best I can get with Unset Printing Notations is the
following, which is still non-trivial to parse:
forall (A : Type) (x y : A), eq x y -> eq y x
: Prop
> As far as launching coqtop with ideslave in trunk, this works for me but I
> don't understand the new async proofs protocol (I picked the control
> channel port randomly):
> coqtop -main-channel stdfds -control-channel 127.0.0.1:60875
> <http://127.0.0.1:60875> -ideslave -async-proofs on
> I would also like to hear more generally how to understand the XML protocol.
> -Tej
> On Tue, Jun 30, 2015 at 4:01 AM Clément Pit--Claudel
> <mailto:clement.pit AT gmail.com>>
> wrote:
> Hi all,
> Is there a way to print a structured representation of a lemma's
> statement in Coq? Ideally I'd like to get something like (forall ((A type)
> (x A) (y A)) (impl (eq x y) (eq y x))) given the lemma [forall A (x y: A),
> x = y -> y = x].
> * Basic extracting to JSON doesn't do, because Props are erased before
> extraction.
> * The PrintAst XML command looks promising, but I'm not sure what its
> syntax is. [1]
> * The code in texmacspp.ml <http://texmacspp.ml> also looks promising,
> but I have no idea how to call into it.
> Thanks!
> [1] More generally, I'm not sure how to invoke the IDE slave mode in
> trunk: the following command works with 8.4pl2, but on trunk it prints
> "Fatal error: ideslave communication channels not set.":
> coqtop -ideslave <<< '<call val="mkcases">nat</call>'
