- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Printing a structured representation of a Prop?
- Date: Tue, 30 Jun 2015 20:37:30 -0700
On 06/30/2015 04:26 PM, Jason Gross wrote:
> You might or might not find Gregory's template-coq plugin
> <https://github.com/gmalecha/template-coq> useful, which lets you dump the
> kernel representation of terms into a Gallina datatype.
Thanks; ideally, though, I'd like to not have to depend on extra plugins,
given that all the code required for printing seems to already exist in
texmacspp.ml.
Clément.
> On Tue, Jun 30, 2015 at 7:07 PM, Valentin Robert
> <vrobert AT cs.ucsd.edu
> <mailto:vrobert AT cs.ucsd.edu>>
> wrote:
> I am currently working on understanding the new XML protocol on 8.5,
> with help from Stuart Pernsteiner.
> So far, we have found that:
> - the simplest command to invoke it is:
> coqtop -ideslave -main-channel stdfds
> - a useful command to learn about the new protocol is:
> coqtop -ideslave --help-XML-protocol
> - the new system sends <message> and <feedback> messages, with some
> information in this file:
> https://github.com/coq/coq/blob/trunk/lib/feedback.ml
> - this file contains some information about what the commands actually
> do and the type of their arguments:
> https://github.com/coq/coq/blob/trunk/ide/interface.mli
> Best luck,
> - Valentin
> On Tue, Jun 30, 2015 at 5:26 AM Tej Chajed
> <tchajed AT mit.edu
> <mailto:tchajed AT mit.edu>>
> wrote:
> Can you just disable notation? (Unset Printing Notations, or the
> View menu in CoqIDE). If you're using Check you might have to re-run the
> command after disabling.
> As far as launching coqtop with ideslave in trunk, this works for
> me but I don't understand the new async proofs protocol (I picked the
> control channel port randomly):
> coqtop -main-channel stdfds -control-channel 127.0.0.1:60875
> <http://127.0.0.1:60875> -ideslave -async-proofs on
> I would also like to hear more generally how to understand the XML
> protocol.
> -Tej
> On Tue, Jun 30, 2015 at 4:01 AM Clément Pit--Claudel
> <mailto:clement.pit AT gmail.com>>
> wrote:
> Hi all,
> Is there a way to print a structured representation of a
> lemma's statement in Coq? Ideally I'd like to get something like (forall
> ((A type) (x A) (y A)) (impl (eq x y) (eq y x))) given the lemma [forall A
> (x y: A), x = y -> y = x].
> * Basic extracting to JSON doesn't do, because Props are erased
> before extraction.
> * The PrintAst XML command looks promising, but I'm not sure
> what its syntax is. [1]
> * The code in texmacspp.ml <http://texmacspp.ml> also looks
> promising, but I have no idea how to call into it.
> Thanks!
> [1] More generally, I'm not sure how to invoke the IDE slave
> mode in trunk: the following command works with 8.4pl2, but on trunk it
> prints "Fatal error: ideslave communication channels not set.":
> coqtop -ideslave <<< '<call val="mkcases">nat</call>'
- Re: [Coq-Club] Printing a structured representation of a Prop?, Valentin Robert, 06/30/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Jason Gross, 07/01/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Clément Pit--Claudel, 07/01/2015
- <Possible follow-up(s)>
- Re: [Coq-Club] Printing a structured representation of a Prop?, Emilio Jesús Gallego Arias, 07/01/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Pierre Courtieu, 07/01/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Clément Pit--Claudel, 07/02/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Emilio Jesús Gallego Arias, 07/08/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Clément Pit--Claudel, 07/09/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Enrico Tassi, 07/01/2015
- Re: [Coq-Club] Printing a structured representation of a Prop?, Valentin Robert, 07/02/2015
