- From: Konstantin Weitz <weitzkon AT cs.washington.edu>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Running Coq without installing it?
- Date: Tue, 21 Jul 2015 09:26:37 -0700
You can also try Valentin's PeaCoq. It's a web based frontend to Coq that has been used in classrooms before.
http://goto.ucsd.edu/~vrobert/coq-en-stock/blog/
- Konstantin
On Jul 21, 2015 2:36 AM, "Matej Grabovský" <mgrabovsky AT yahoo.com> wrote:
Hi.There's also Js Coq <https://github.com/ejgallego/jscoq>, nota bene it's in a very experimental stage of development, so it might not be exactly what you're looking for.Best regards,Matej G.On Tuesday, July 21, 2015 8:55 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,I'm teaching a class on Coq on Wednesday, and discovered Coq has not been installed on the computers I will be using. Is there a way to run Coq on Windows and/or Mac without installing it (e.g., is there a run-from-a-flash-drive / portable version of Coq? Are there websites that will let students run Coq programs and see the output? There was a thread about this a year ago that mentioned ProofWeb and cloud.sagemath, but I'm curious if there are more options now.)Thanks,Jason
- [Coq-Club] Running Coq without installing it?, Jason Gross, 07/21/2015
- Re: [Coq-Club] Running Coq without installing it?, Vincent Siles, 07/21/2015
- Re: [Coq-Club] Running Coq without installing it?, Amin Timany, 07/21/2015
- Re: [Coq-Club] Running Coq without installing it?, Matej Grabovský, 07/21/2015
- Re: [Coq-Club] Running Coq without installing it?, Konstantin Weitz, 07/21/2015
- Re: [Coq-Club] Running Coq without installing it?, Joseph Redmon, 07/21/2015
- Re: [Coq-Club] Running Coq without installing it?, Valentin Robert, 07/21/2015
