- From: richard dapoigny <richard.dapoigny AT univ-savoie.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite with setoid equality
- Date: Tue, 21 Jul 2015 16:57:46 +0200
- Organization: LISTIC
Thanks a lot Matthieu. It was a problem
of parentheses!
The correct form is: Lemma ProtoTh5 : forall (p q:Prop), (forall f:Morphism, p ≡≡ ((forall r, (p ≡≡ f r)) ≡≡ (forall r, (q ≡≡ f r)))) -> q. (T is a parameter of the module and then, there is no need to provide it in the arguments) Cheers, Richard Le 21/07/2015 16:13, Matthieu Sozeau a écrit : Hi Richard,
I suppose it's your parentheses that are incorrect:
Lemma ProtoTh5 : forall (p q:Prop), forall (T
:Morphism), (forall f:Morphism,
forall r, (q ≡≡ f r))) -> q.
would probably be better (notice the forall r0 renaming
in your version).
Cheers,
-- Matthieu
On Tue, Jul 21, 2015 at 4:03 PM richard dapoigny
wrote:
Le 21/07/2015 14:29, Matthieu Sozeau a écrit :
Hi Matthieu,
Just before the rewrite tactic, i.e., with: ================================================ Lemma ProtoTh5 : forall (p q:Prop), (forall f:Morphism, p ≡≡ (forall r, (p ≡≡ f r) ≡≡ forall r, (q ≡≡ f r))) -> q. Proof. intros p q H1. specialize (H1 T). assert (H2:(forall p:Prop, (forall r, p ≡≡ T r) ≡≡ p)). apply ProtoTh4. assert (H3:=H2). specialize (H2 p). specialize (H3 q).
I have the following demonstration step: ================================================ 1 subgoals p : Prop q : Prop H1 : p ≡≡ (forall r : Prop, (p ≡≡ T r) ≡≡ (forall r0 : Prop, q ≡≡ T r0)) H2 : (forall r : Prop, p ≡≡ T r) ≡≡ p H3 : (forall r : Prop, q ≡≡ T r) ≡≡ q ______________________________________(1/1) q =============================================== The objective is to rewrite (forall r : Prop, p ≡≡ T r) with p in the _expression_ of H1 (and the same job for (forall r : Prop, q ≡≡ T r) in such a way to get the form: H1 : p ≡≡ (p ≡≡ q) Cheers, Richard |
- [Coq-Club] Rewrite with setoid equality, Richard Dapoigny, 07/21/2015
- Re: [Coq-Club] Rewrite with setoid equality, Matthieu Sozeau, 07/21/2015
- Re: [Coq-Club] Rewrite with setoid equality, richard dapoigny, 07/21/2015
