- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Are Prop and Set interchangable?
- Date: Sat, 01 Aug 2015 21:56:33 +0900
Hi,
I am currently learning COQ. Why is the sequence below valid? Are Prop and Set terms interchangable?
Variable n : Prop.
Variable f : Set -> nat.
Check (f n).
f n : nat
Regards,
Yasuaki
- [Coq-Club] Are Prop and Set interchangable?, yasu, 08/01/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, Gabriel Scherer, 08/01/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, yasu, 08/02/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, Kristopher Micinski, 08/02/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, Yasuaki Kudo, 08/02/2015
