- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Are Prop and Set interchangable?
- Date: Sun, 02 Aug 2015 14:18:26 +0900
Hi,
Thank you, this helps a lot! On page 38, 2.5.2 Universes in Interactive Theorem Proving and Program Development, it says:
Level 0: programs and basic values
Level 1: specifications and data types
Level 2: the Set sort
Level 3: the universe Type(0)
Level i+3: the universe Type(i)
Where is Prop in this, Level 2?
Cheers,
Yasuaki
On 01.08.2015 22:40, Gabriel Scherer wrote:
Prop and Set are two universes of types, and Prop is included in Set.
The different can be felt in various ways, including:
- a value in Prop can be seen as a value in Set (but the converse is not true)
- the rules to build terms whose type is in Prop are stricter than
those to build terms whose type is in Set (constructions by
case-distinction are restricted if you want to create a Prop)
- quantifying on all types in Prop is a "small quantification" (the
resulting polymorphic type is itself in Prop), while quantifying on
all types in Set (it quantifies on more things) is a "large
quantification" (the resulting polymorphic type lives in a strictly
larger universe)
I think this should be explained in most documents teaching Coq -- in
a section on the universe hierarchy.
On Sat, Aug 1, 2015 at 2:56 PM,
<yasu AT yasuaki.com>
wrote:
Hi,
I am currently learning COQ. Why is the sequence below valid? Are Prop and
Set terms interchangable?
Variable n : Prop.
Variable f : Set -> nat.
Check (f n).
f n : nat
Regards,
Yasuaki
- [Coq-Club] Are Prop and Set interchangable?, yasu, 08/01/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, Gabriel Scherer, 08/01/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, yasu, 08/02/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, Kristopher Micinski, 08/02/2015
- Re: [Coq-Club] Are Prop and Set interchangable?, Yasuaki Kudo, 08/02/2015
