coq-club - Re: [Coq-Club] Difference between sum and sumbool
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Difference between sum and sumbool
  • Date: Tue, 25 Aug 2015 13:59:36 +0200
On 25/08/2015 13:46, Dirk Pattinson wrote:
I agree but am struggling to understand when sum and sumbool are applied
to arguments of type Prop. In this case, it appears that both carry one
bit of computational information: left or right, and the computational
information of sum P Q (where P Q: Prop) isn't usable outside Prop, either.
A value of type "sumbool A B" carries a single bit of information. A value of type "sum A B" carries one bit of information or more (depending on whether values of types A and B carry any bit of information). This bit of information, for both sumbool and sum, can be used outside Prop, whether A and B are of type Prop or not. (It is the "or A B" type that does not carry any bit of information and thus cannot be destructed to get a value of a type outside Prop.)
Differently put: assuming I'm not interested in extraction, could I
replace "sumbool" by "sum" throughout (assuming I would be prepared to
also do this in the libraries)?
Yes.
Definition sumbool : Prop -> Prop -> Set := sum.
Best regards,
Guillaume
