coq-club - Re: [Coq-Club] Difference between sum and sumbool
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Difference between sum and sumbool
  • Date: Tue, 25 Aug 2015 09:51:11 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jwiegley AT gmail.com; spf=Pass smtp.mailfrom=jwiegley AT gmail.com; spf=None smtp.helo=postmaster AT mail-pa0-f52.google.com
  • Ironport-phdr: 9a23:Q+NVMhG49cribkFK4VlAUp1GYnF86YWxBRYc798ds5kLTJ75pMWwAkXT6L1XgUPTWs2DsrQf27GQ7vGrBzJIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/njKbvqtaNPU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y5WcGIWlFJ3AgXK6BzrFN+lsCz6sPVV3iSFNNfqTKs9Xy/k5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
  • Organization: New Artisans LLC
>>>>> Dirk Pattinson
>>>>> <dirk.pattinson AT anu.edu.au>
>>>>> writes:
> Differently put: assuming I'm not interested in extraction, could I replace
> "sumbool" by "sum" throughout (assuming I would be prepared to also do this
> in the libraries)?
sum ranges over Type, so sumbool is just a fixed specialization to Prop. So
you can use sum anywhere you might use sumbool, with the noted difference that
for extraction purposes, sumbool is Bool, and sum over Prop is Either () ().
John
