coq-club - Re: [Coq-Club] : is ∀A: Prop, ∼∼(A∨∼A) provable in Coq?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] : is ∀A: Prop, ∼∼(A∨∼A) provable in Coq?
  • Date: Thu, 03 Sep 2015 20:03:58 +0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=shengyushen AT icloud.com; spf=Pass smtp.mailfrom=shengyushen AT icloud.com; spf=None smtp.helo=postmaster AT pv33p04im-asmtp001.me.com
  • Ironport-phdr: 9a23:uHZvChPJZvy4OY/AoGIl6mtUPXoX/o7sNwtQ0KIMzox0KP/zrarrMEGX3/hxlliBBdydsKIYzbKK+Py9EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35jxj7z5p8CbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7a/XsRVGoHj1JTAwXDpEXhXpr3vTrnrepw3gGbNsnxULxyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
This explanation is much more elaborate, thanks
Shen
On Sep 3, 2015, at 5:26 PM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
Let me complete Pierre's answer a little. Because it is easy to find this proof a bit mysterious.
First, excluded middle is `∀A:Prop, A∨¬A`. It is evidently at least as strong as `∀A:Prop, ¬¬(A∨¬A)`. And since the latter is provable in Coq, excluded middle is actually stronger. It is a general principle in constructive mathematics that adding double-negations in a statement can be used to make it weaker: an equivalent principle to excluded middle is double-negation elimination `∀A:Prop, ¬¬A→A`, since it doesn't hold in constructive mathematics, adding double-negation makes it, in general, easier to prove a statement.
The principle behind the proof of `∀A:Prop, ¬¬(A∨¬A)` is as follows.
First remark that `∀A:Prop, ¬(A∧¬A)` is provable. The definition of `¬A` being "a contradiction can be derived from `A`", it should be reasonably clear that this property holds in Coq.
The next step is to prove that `∀A B:Prop, ¬(A∨B) → ¬A∧¬B` (in fact it is an equivalence). This is a de Morgan law which holds even without excluded middle. It is true because given a proof of `A`, I can build a proof of `A∨B` which together with `¬(A∨B)` is contradictory, so `¬A` follows from `¬(A∨B)`. Symmetrically, so does `¬B`.
Now, suppose `¬(A∨¬A)`, by the above property, we have `¬A∧¬¬A`. By the first remark, we have a contradiction. Qed.
On 3 September 2015 at 11:03, Pierre Casteran <pierre.casteran AT labri.fr> wrote:
Hi,
 Assuming ~(A \/ ~A), you first prove ~A, then find a contradiction.
Goal  forall A:Prop, ~ ~(A \/ ~A).
intros A H.
apply H.
right;intro a.
destruct H;now left.
Qed.
Pierre
Le 03/09/2015 10:54, shengyu shen a écrit :
Dear all:
I am trying to prove an exercise in coq art “∀A: Prop, ∼∼(A∨∼A).”
I think this may need exclude middle rule, which is not in “Calculus of
Inductive Constructions“
am I right?
Shen
