- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] difference between simpl and unfold
- Date: Thu, 03 Sep 2015 20:15:17 +0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=shengyushen AT icloud.com; spf=Pass smtp.mailfrom=shengyushen AT icloud.com; spf=None smtp.helo=postmaster AT pv33p04im-asmtp001.me.com
- Ironport-phdr: 9a23:zoFsShe8m8TE8hgRujysdfoJlGMj4u6mDksu8pMizoh2WeGdxc65bB7h7PlgxGXEQZ/co6odzbGG7+a4BSdcvN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDuvcWPKFkVzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OUg04tfqvF/NV1ih/HwZB34WnxxHEhWN9xH3WN+lqSv3sOVsxTKaMMveTLswXimuqaxsTUm72288Kzcl/TSP2YRLh6VBrUf5qg==
according to doc of coq, there are 4 types of reduction:
beta, delta, iota or zeta.
It seems that simple work on beta iota and zeta, while unfold work on delta only?
Shen
On Sep 3, 2015, at 6:17 PM, Pierre Courtieu <pierre.courtieu AT gmail.com> wrote:You can see the behavior of simpl, cbn and unfold in the documentation.
In short: simpl is reduction heuristic. It only unfolds if some
further reduction (iota-reduction mainly I think) is triggered by the
unfolding, otherwise it does not unfold (to keep you goal small).
Remark: please use cbn instead of simpl if you are using coq-8.5. Its
behavior is most of the time better.
Hope this helps
P.
2015-09-02 16:10 GMT+02:00 shenshengyu <shengyushen AT me.com>:Dear all:
I am a new leaner of Coq, I am reading the usage of tactics.
I am trying to prove the following theorem:
Theorem double_neg_i: forall P:Prop , P->~~P.
if I use “unfold not.” , I can transform the goal to
forall P : Prop, P -> (P -> False) -> False
But if I use “simpl not”, then nothing happen.
So my question is what is the difference of simpl and unfold?
Shen
- [Coq-Club] difference between simpl and unfold, shenshengyu, 09/02/2015
- Re: [Coq-Club] difference between simpl and unfold, Pierre Courtieu, 09/03/2015
- Re: [Coq-Club] difference between simpl and unfold, shengyu shen, 09/03/2015
