coq-club - [Coq-Club] How to simplify / compute with a recursive "Function" definition
  • From: Washington Ribeiro <wtonribeiro AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] How to simplify / compute with a recursive "Function" definition
  • Date: Fri, 4 Sep 2015 17:08:33 -0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wtonribeiro AT gmail.com; spf=Pass smtp.mailfrom=wtonribeiro AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f181.google.com
  • Ironport-phdr: 9a23:DVAcDRArO8bFB7KlG/HSUyQJP3N1i/DPJgcQr6AfoPdwSP7/osbcNUDSrc9gkEXOFd2CrakU16yO7eu5BTFIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/ni6bqpdaKP1gArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5JbWwNkhtODBTC6lnAX538szH9/r5ixC6cJ8z8QLEuXhyt6q5qTFnjjyJRZG1xy33elsEl1PETmxmmvREqm4M=
Dears,
I've defined a function with a specific measure by the "Function" style:
Function equiv_rec (T :  Context * (term * term ))
 {measure size_term_triple} : Prop :=
 match T with
 end.
I get a proof of the measure decreasing and so equiv_rec was defined as the adjacent lemmas:
equiv_rec_tcc is defined
equiv_rec_terminate is defined
equiv_rec_ind is defined
equiv_rec_rec is defined
equiv_rec_rect is defined
R_equiv_rec_correct is defined
R_equiv_rec_complete is defined
equiv_rec is defined
equiv_rec_equation is defined
But when I try do apply in the future lemmas some simple tactics like "simpl" or "compute" it doesn't work.
Someone can help me?
Best,
Washington Segundo
