Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition
- Date: Mon, 07 Sep 2015 15:37:32 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-pa0-f53.google.com
- Ironport-phdr: 9a23:zdBTKxVHMPvlIaRn1XIImY7u4mrV8LGtZVwlr6E/grcLSJyIuqrYZheBt8tkgFKBZ4jH8fUM07OQ6PC8HzVYqsfb+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVOl0D1WD1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDtxNUHwjE4QyyZZDjvyLn/r540TWGNMjeSLkoRT2nqaBxR0m72288Kzcl/TSP2YRLh6VBrUf5qg==
Hi Washington,
you need to use rewriting with the equiv_rec_equation lemma that is generated I think.
Best,
-- Matthieu
On Fri, Sep 4, 2015 at 10:08 PM Washington Ribeiro <wtonribeiro AT gmail.com> wrote:
But when I try do apply in the future lemmas some simple tactics like "simpl" or "compute" it doesn't work.I get a proof of the measure decreasing and so equiv_rec was defined as the adjacent lemmas:Dears,I've defined a function with a specific measure by the "Function" style:
Function equiv_rec (T : Context * (term * term ))
{measure size_term_triple} : Prop :=
match T with
end.
equiv_rec_tcc is defined
equiv_rec_terminate is defined
equiv_rec_ind is defined
equiv_rec_rec is defined
equiv_rec_rect is defined
R_equiv_rec_correct is defined
R_equiv_rec_complete is defined
equiv_rec is defined
equiv_rec_equation is defined
Someone can help me?Best,Washington Segundo
- [Coq-Club] How to simplify / compute with a recursive "Function" definition, Washington Ribeiro, 09/04/2015
- Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition, Matthieu Sozeau, 09/07/2015
- Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition, Pierre Courtieu, 09/07/2015
- Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition, Washington Ribeiro, 09/07/2015
- Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition, Pierre Courtieu, 09/09/2015
- Re: [Coq-Club] How to simplify / compute with a recursive "Function" definition, Washington Ribeiro, 09/14/2015
