- From: Francois Pottier <Francois.Pottier AT inria.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] New release of Menhir (20150921)
- Date: Wed, 23 Sep 2015 08:52:28 +0200
Dear Coq users,
A new release of Menhir (20150921) is available via opam (just run "opam
install menhir") and from http://gallium.inria.fr/~fpottier/menhir/ .
The relevant chunk of the CHANGES file is appended at the end of this message.
Here is a summary of the most important changes:
- The Coq back-end (designed and implemented by Jacques-Henri Jourdan) has
been documented. Yes, Menhir can produce a provably correct parser, written
in Coq's programming language.
- The incremental API has been changed (in an incompatible way), and a new
inspection API has appeared. Expect more incompatible changes in the future,
as these APIs are not yet mature.
- Added support for anonymous rules. This allows writing, e.g.,
list(e = expression SEMI { e })
whereas previously one should have written
list(terminated(e, SEMI)).
Best regards,
François Pottier
2015/09/21:
Re-established some error messages concerning the mis-use of $i which
had disappeared on 2015/06/29.
2015/09/11:
Fixed the mysterious message that would appear when a nonterminal symbol
begins with an uppercase letter and --infer is turned on. Clarified the
documentation to indicate that a (non-start) nonterminal symbol can begin
with an uppercase letter, but this is not recommended.
2015/08/27:
New option --inspection (added last January, documented only now). This
generates an inspection API which allows inspecting the automaton's stack,
among other things. This API can in principle be used to write custom code
for error reporting, error recovery, etc. It is not yet mature and may
change in the future.
2015/07/20:
Added the command line options --unused-token <symbol> and --unused-tokens.
2015/06/29:
Changed the treatment of the positional keywords $i. They are now
rewritten into variables of the form '_i' where 'i' is an integer.
Users are advised not to use variables of this form inside semantic
actions.
2015/02/11:
2015/02/09:
Moved all of the demos to ocamlbuild (instead of make).
2015/01/18:
Incompatible change of the incremental API.
The incremental API now exposes shift events too.
2015/01/16:
Fixed a couple bugs in Makefile and src/Makefile which would cause
compilation and installation to fail with "TARGET=byte". (Reported
by Jérémie Courrèges-Anglas and Daniel Dickman.)
2015/01/01:
The entry point main_incremental is now named Incremental.main.
2014/12/29:
The API now exposes reduction events.
The type 'a result is now private.
The type env is no longer parameterized.
[handle] is renamed to [resume].
[offer] and [resume] now expect a result, not an environment.
2014/12/22:
Documented the Coq back-end (designed and implemented by Jacques-Henri
Jourdan).
- [Coq-Club] New release of Menhir (20150921), Francois Pottier, 09/23/2015
- Re: [Coq-Club] New release of Menhir (20150921), Gabriel Scherer, 09/23/2015
- Re: [Coq-Club] New release of Menhir (20150921), Francois Pottier, 09/23/2015
