coq-club - Re: [Coq-Club] Coq 8.2 compatibility issues
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Coq 8.2 compatibility issues
  • Date: Wed, 23 Sep 2015 10:03:38 +0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wilayatk AT gmail.com; spf=Pass smtp.mailfrom=wilayatk AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f54.google.com
  • Ironport-phdr: 9a23:toL/qRXmVaANBDjWRGAhD7/p0OzV8LGtZVwlr6E/grcLSJyIuqrYZheDt8tkgFKBZ4jH8fUM07OQ6PC8HzBZqsvd+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVP1wD2Wb1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDrRtMChnM8FnZXp73+n/lt+50ySCGPuX5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
Hi Lars
 Thanks for the reply. I am wondering, why are the binaries downloaded from the site not working. If I am not mistaken, I had just installed the windows version of Coq 8.2 downloaded from https://coq.inria.fr/coq-82-detailed-description, while I can install it now but then can not run the binary coqide.exe. I will try building the binaries anyway.
Wilayat
On Tue, Sep 22, 2015 at 11:04 PM, Lars Rasmusson <Lars.Rasmusson AT sics.se> wrote:
If you don't have the binaries anymore, perhaps you can build it from sources?
There is an 8.2 branch in the git repo.
On Mon, Sep 21, 2015 at 10:49 AM, Wilayat Khan <wilayatk AT gmail.com> wrote:
Hello
  I can not run my old Coq script (developed with Coq 8.2 on Windows 7, 4 years ago) on Coq 8.3 or later (even if use option  [-compat 8.2]) , nor can execute Coq 8.2 (downloaded from official website) on Windows XP, Vista, 8 or 10 (complaining compatibility).
 Would be happy if I get Coq 8.2 that can work on Windows or compile the script on Coq 8.3 or later without manually resolving all the compatibilities in my code.
 Any idea?  Thanks,
 Wilayat
