- From: Andrew Polonsky <andrew.polonsky AT gmail.com>
- To: Homotopy Type Theory <HomotopyTypeTheory AT googlegroups.com>
- Cc: homotopytypetheory AT googlegroups.com, vladimir AT ias.edu, coq-club AT inria.fr
- Subject: Re: [Coq-Club] a question
- Date: Mon, 28 Sep 2015 04:01:56 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=andrew.polonsky AT gmail.com; spf=Pass smtp.mailfrom=andrew.polonsky AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f56.google.com
- Ironport-phdr: 9a23:h+S/0hZfXSHU3IKt12zR6Af/LSx+4OfEezUN459isYplN5qZpMy9bnLW6fgltlLVR4KTs6sC0LqK9f29Ejdbqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7z0psCYOF4ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6v4X4bTmIOg1J0EhDIpC36U5Dro2Oulu143zWdJdzKXKg5ZTSv6L16YBDvjygDOjEj93zPkYp7i6cN8zy7oBkq6ojYeoyKfMJ5eqTbZtALDT5IWMpLWjMHGoS4aI0UDPspMuNRro27rFwL+0jtTTKwDf/in2cbzkT92rc3hqF4SVnL
On Monday, September 28, 2015 at 10:20:06 AM UTC+2, v v wrote: The cubical type theory is the first one that accomplishes both without assuming some form of truncation. (Modulo normalization proof.)
Is it correct to say that the main problem in constructive type theory is to create a type theory that simultaneously satisfies two conditions:
1. the function extensionality principle
2. the principle of decidability of typing judgements
Andrew
Is it right that no such theory exists?
Vladimir.
- Re: [Coq-Club] a question, Pierre Courtieu, 09/01/2015
- <Possible follow-up(s)>
- [Coq-Club] a question, Vladimir Voevodsky, 09/28/2015
- Re: [Coq-Club] a question, Peter LeFanu Lumsdaine, 09/28/2015
- Re: [Coq-Club] [HoTT] Re: a question, Bas Spitters, 09/28/2015
- Re: [Coq-Club] [HoTT] Re: a question, Martin Escardo, 09/28/2015
- Re: [Coq-Club] a question, Jean-Francois Monin, 09/28/2015
- Re: [Coq-Club] a question, Thorsten Altenkirch, 09/28/2015
- Re: [Coq-Club] a question, Gabriel Scherer, 09/28/2015
- Re: [Coq-Club] a question, Andrew Polonsky, 09/28/2015
