- From: Petar Maksimovic <petar.maksimovic AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Records and Inductive definitions
- Date: Thu, 1 Oct 2015 16:13:54 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=petar.maksimovic AT gmail.com; spf=Pass smtp.mailfrom=petar.maksimovic AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f175.google.com
- Ironport-phdr: 9a23:XTLOBhCMZYQ37mMknuF+UyQJP3N1i/DPJgcQr6AfoPdwSP7/ocbcNUDSrc9gkEXOFd2CrakU16yI6eu/BSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTrkb7osMKPKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs0MRTmwM2j9BABPE6RbkX5y55jP3quNnniyTPtb3SLcqWD+K4KJiSRuugyACYW1quFrLg9B92foI6CmqoAZyltbZ
Thanks Pierre-Marie and Epiphanie,
Vectors would work if my example hadn't been somewhat
under-illustrative. What I would really like is
Record list_noDup (T : Type) := {lT :> list T; cond: noDup lT}.
Inductive T : Type :=
| T_main : list_noDup T -> T.
but for that I think I'll need some sort of workaround.
Cheers,
Petar
On 1 October 2015 at 15:59, Epiphanie
<landeguy AT gmail.com>
wrote:
> Dear Petar,
> Strictly positive occurrence states that you are not allowed to create a
> type from a function that takes an argument of this type (the reason for
> this is obvious if you consider omega in lambda calculus)
> So I believe the reason it does not work is that cond has the type T -> list
> T -> Prop that guarantees that your list is a singleton.
> So cond cannot be in the constructor of the type you want to define, T
> I am not sure I understand exactly what you want to do, but it seems like
> you want to map list of one element onto the type of this element
> In which case, you could try to do a coercion between the two
> Cheers,
> Epiphanie
> Le 1 octobre 2015 15:12:55 UTC+02:00, Petar Maksimovic
> a écrit :
>> Dear Michael,
>> I don't think that is the problem leading to the error message,
>> because this works:
>> | T_main : list T -> T.
>> and something like this also works:
>> Record list_singleton (T : Type) := {lT :> list T; n : nat; cond : n >
>> 37}.
>> | T_main : list_singleton T -> T.
>> I think that the length condition that I had (length lT = 1) is
>> causing the issue, but I don't quite understand why.
>> Best regards,
>> Petar
>> On 1 October 2015 at 14:59, Soegtrop, Michael
>> <michael.soegtrop AT intel.com>
>> wrote:
>>> Dear Petar,
>>> you wrote that T can be a list of itself, which justifies this error
>>> message. Maybe you meant this (which does work):
>>> Type) := {lT :> list T; cond : length lT = 1}.
>>> Inductive SomeInd (T : Type) :=
>>> | T_main : list_singleton T -> SomeInd T.
>>> Best regards,
>>> Michael
>>> -----Original Message-----
>>> From:
>>> coq-club-request AT inria.fr
>>> [mailto:coq-club-request AT inria.fr]
>>> On
>>> Behalf Of Petar Maksimovic
>>> Sent: Thursday, October 01, 2015 2:28 PM
>>> To:
>>> Any comments? From the developer team, in particular, perhaps? :)
>>> Cheers,
>>> Petar
>>> On 28 September 2015 at 17:27, Petar Maksimovic
>>> wrote:
>>>> Hello everyone,
>>>> Why is it not possible to do the following in Coq:
>>>> Record list_singleton (T : Type) := {lT :> list T; cond : length lT =
>>>> 1}.
>>>> It fails with the error message: Error: Non strictly positive
>>>> occurrence of "T" in "list_singleton T -> T".
>>>> I feel that this should be able to go through, since
>>>> would go through, and I am simply putting an extra condition on the
>>>> lists that I allow.
>>>> What I would ultimately want is to be able to use Coq's finite maps in
>>>> constructors, somewhat like this:
>>>> Module FMnat := FMapWeakList.Make(Nat_as_OT). (or FMapFullAVL, for
>>>> that matter)
>>>> Definition FMap := FMnat.t.
>>>> | T_main : FMap T -> T.
>>>> and I believe that the problem (in this case) boils down to a
>>>> restriction condition in the underlying record definition of slist, on
>>>> which FMapWeakList is based, therefore the simplified example above.
>>>> Any ideas, including how
>>>> I could approach this differently, are very
>>>> appreciated.
>>>> Thank you,
>>>> Petar
>>>> P.S. The following does not go through:
>>>> | T_main : forall T', list_whatever T T' -> T with Record
>>>> list_whatever (T T' : Type) := {lT :> list T; whatever : T'}.
>>>> with the error message: Error: Cannot handle mutually (co)inductive
>>>> records, whereas
>>>> Record list_whatever (T T' : Type) := {lT :> list T; whatever : T'}.
>>>> | T_main : forall T', list_whatever T T' -> T.
>>>> goes through just fine. Why is this so?
>>> Intel Deutschland GmbH
>>> Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
>>> Tel: +49 89 99 8853-0, www.intel.de
>>> Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
>>> Chairperson of the Supervisory Board: Tiffany Doon Silva
>>> Registered Office:
>>> Munich
>>> Commercial Register: Amtsgericht Muenchen HRB 186928
- Re: [Coq-Club] Records and Inductive definitions, Petar Maksimovic, 10/01/2015
- RE: [Coq-Club] Records and Inductive definitions, Soegtrop, Michael, 10/01/2015
- Re: [Coq-Club] Records and Inductive definitions, Pierre-Marie Pédrot, 10/01/2015
- Re: [Coq-Club] Records and Inductive definitions, Epiphanie, 10/01/2015
- Re: [Coq-Club] Records and Inductive definitions, Petar Maksimovic, 10/05/2015
