- From: Petar Maksimovic <petar.maksimovic AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Records and Inductive definitions
- Date: Mon, 5 Oct 2015 01:03:49 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=petar.maksimovic AT gmail.com; spf=Pass smtp.mailfrom=petar.maksimovic AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f172.google.com
- Ironport-phdr: 9a23:17rgORaLBYsBZZDnh27Fq3X/LSx+4OfEezUN459isYplN5qZpciybnLW6fgltlLVR4KTs6sC0LqK9f6/EjVQut6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDuvcOMKFwY33KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzAunwZBGUDg5RLhX5L2rCrx/r5l1TWTJ4vzRLMvWDGl8aZgYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
Hi Michael,
I think in the end I'll have to go with a duplication-free list type,
and try to use just the noDup fact and not implement the entire fmap
interface. I'm afraid I don't have the resources (time, mostly) at the
moment for porting stdlib in the way you suggested.
Thanks, cheers,
Petar
On 1 October 2015 at 16:30, Soegtrop, Michael
<michael.soegtrop AT intel.com>
wrote:
> Dear Petar,
> in this case it might be easier to use a set type or duplication free list
> type. In my experience it is much more pain to carry along the witnesses in
> dependent types than to use types which have the desired properties by
> construction.
> Unfortunately the set types in the standard library are implemented with
> modules and are not first class polymorphic, but if lists are performance
> wise ok as set representation for you, it is easy to define. If not, I
> would be interested to work together on porting relevant standard libraries
> (tree based sets) to type class based first class polymorphic
> implementations.
> Best regards,
> Michael
> -----Original Message-----
> From:
> coq-club-request AT inria.fr
> [mailto:coq-club-request AT inria.fr]
> On Behalf Of Petar Maksimovic
> Sent: Thursday, October 01, 2015 4:14 PM
> To:
> Thanks Pierre-Marie and Epiphanie,
> Vectors would work if my example hadn't been somewhat under-illustrative.
> What I would really like is
> Record list_noDup (T : Type) := {lT :> list T; cond: noDup lT}.
> Inductive T : Type :=
> | T_main : list_noDup T -> T.
> but for that I think I'll need some sort of workaround.
> Cheers,
> Petar
> Intel Deutschland GmbH
> Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
> Tel: +49 89 99 8853-0, www.intel.de
> Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
> Chairperson of the Supervisory Board: Tiffany Doon Silva
> Registered Office: Munich
> Commercial Register: Amtsgericht Muenchen HRB 186928
- Re: [Coq-Club] Records and Inductive definitions, Petar Maksimovic, 10/01/2015
- RE: [Coq-Club] Records and Inductive definitions, Soegtrop, Michael, 10/01/2015
- Re: [Coq-Club] Records and Inductive definitions, Pierre-Marie Pédrot, 10/01/2015
- Re: [Coq-Club] Records and Inductive definitions, Epiphanie, 10/01/2015
- Re: [Coq-Club] Records and Inductive definitions, Petar Maksimovic, 10/05/2015
