- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Help with Opam and OCaml
- Date: Thu, 1 Oct 2015 17:16:49 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beta AT mpi-sws.org; spf=Pass smtp.mailfrom=beta AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:O2y1jxfbsL8PfLpEy/1/HXTDlGMj4u6mDksu8pMizoh2WeGdxc68Yx7h7PlgxGXEQZ/co6odzbGG7+a+AydZvcfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvip9uNOU4R2Gv1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3SNp41Rr1ADTkgL3t9pIiy7UGCHkOz4S43VXxeuR5VCUCR5xbjG5z1ryHSt+xn2SDcM9egHp4uXjH3xap3QVfaiSMGPjg4uDXdh9B5pKdDoVe6uAc5xJTbNtLGfMFid7/QKItJDVFKWdxcAmkYWtux
Hi list,
I have the following issue that is driving me nuts. I have two Ubuntu boxes with practically the same setup. I have a plugin for Coq 8.5 beta 2. However, I can compile it in one machine but not on the other. In the machine where it works, I have OCaml installed in the system (as in /usr/bin), while on the other is in .opam. The error in the second machine is:File "src/myfile.ml4", line 92, characters 13-14:
Parse error: [global] or [entry] expected after uppercase identifier (in
[gextend_body])
File "src/myfile.ml4", line 1:
Error: Error while running external preprocessor
GEXTEND Pcoq.Gram
GLOBAL: myproof_instr;
myproof_instr :
[[ c=Pcoq.Constr.operconstr ; "." -> MyInstr.my_constr c ]];
END
When compiling Coq, the ./configure -local script outputs the text below, where XXX is replaced by specific locations for OCaml: /usr/bin (or lib) for one machine, and .opam in the other.
Any ideas?
Thanks!
Beta
You have GNU Make 3.81. Good!
You have OCaml 4.02.3. Good!
You have Camlp5 6.14. Good!
You have native-code compilation. Good!
No such directory '/home/beta/.opam/4.02.3/lib/ocaml/lablgtk2' (in OCaml library).
LablGtk2 not found:
=> no CoqIde will be built.
Architecture : Linux
Coq VM bytecode link flags : -dllib -lcoqrun -dllpath /home/beta/coq/coq8.5b2/coq-8.5beta2/kernel/byterun
Other bytecode link flags :
OS dependent libraries : -cclib -lunix
OCaml version : 4.02.3
OCaml binaries in : XXX
OCaml library in : XXX
Camlp5 version : 6.14
Camlp5 binaries in : /home/beta/.opam/4.02.3/bin
Camlp5 library in : /home/beta/.opam/4.02.3/lib/camlp5
Native dynamic link support : true
CoqIde : no
Documentation : None
Web browser : firefox -remote "OpenURL(%s,new-tab)" || firefox %s &
Coq web site : http://coq.inria.fr/
LablGtk2 not found:
CoqIde : no
- [Coq-Club] Help with Opam and OCaml, Beta Ziliani, 10/01/2015
- Re: [Coq-Club] Help with Opam and OCaml, Beta Ziliani, 10/02/2015
- Re: [Coq-Club] Help with Opam and OCaml, Gabriel Scherer, 10/02/2015
