coq-club - Re: [Coq-Club] Help with Opam and OCaml
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Help with Opam and OCaml
  • Date: Fri, 2 Oct 2015 09:03:47 -0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=beta AT mpi-sws.org; spf=Pass smtp.mailfrom=beta AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23:q8hJsRE6mlgpRT/wNl/snZ1GYnF86YWxBRYc798ds5kLTJ75ocmwAkXT6L1XgUPTWs2DsrQf27aQ7fyrBTVIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/ni6bsp9aPOk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv+YJa6jxfrw5QLpEF3xmdjltvIy4/SXEGCCI/zM3Vngc2k5DBBGA5xXnVL/wtDH7v6xzwn/JE9fxSOUeVCirp5VqTB7hjiZPYzQ07Gj/j9RxyblEu1SmvRMpkN2cW52cKPcrJvCVRtgdX2cUG58JDyE=
I should add that the minimal example is precisely the code that I wrote:
GEXTEND Pcoq.Gram
GLOBAL: myproof_instr;
  myproof_instr :
    [[ c=Pcoq.Constr.operconstr ; "." -> MyInstr.my_constr c ]];
END
With Ocaml installed in /usr/bin it fails complaining about myproof_instr not being defined, while in .opam's Ocaml it fails at the preprocessor level.
Thanks,
Beta
On Thu, Oct 1, 2015 at 5:16 PM, Beta Ziliani <beta AT mpi-sws.org> wrote:
Hi list,
I have the following issue that is driving me nuts. I have two Ubuntu boxes with practically the same setup. I have a plugin for Coq 8.5 beta 2. However, I can compile it in one machine but not on the other. In the machine where it works, I have OCaml installed in the system (as in /usr/bin), while on the other is in .opam.  The error in the second machine is:
File "src/myfile.ml4", line 92, characters 13-14:
Parse error: [global] or [entry] expected after uppercase identifier (in
  [gextend_body])
File "src/myfile.ml4", line 1:
Error: Error while running external preprocessor
That line is:
GEXTEND Pcoq.Gram
  myproof_instr :
END
When compiling Coq, the ./configure -local script outputs the text below, where XXX is replaced by specific locations for OCaml: /usr/bin (or lib) for one machine, and .opam in the other.
Any ideas?
Thanks!
Beta
You have GNU Make 3.81. Good!
You have OCaml 4.02.3. Good!
You have Camlp5 6.14. Good!
You have native-code compilation. Good!
No such directory '/home/beta/.opam/4.02.3/lib/ocaml/lablgtk2' (in OCaml library).
LablGtk2 not found:
=> no CoqIde will be built.
  Architecture                : Linux
  Coq VM bytecode link flags  : -dllib -lcoqrun -dllpath /home/beta/coq/coq8.5b2/coq-8.5beta2/kernel/byterun
  Other bytecode link flags   :
  OS dependent libraries      : -cclib -lunix
  OCaml version               : 4.02.3
  OCaml binaries in           : XXX
  OCaml library in            : XXX
  Camlp5 version              : 6.14
  Camlp5 binaries in          : /home/beta/.opam/4.02.3/bin
  Camlp5 library in           : /home/beta/.opam/4.02.3/lib/camlp5
  Native dynamic link support : true
  CoqIde                      : no
  Documentation               : None
  Web browser                 : firefox -remote "OpenURL(%s,new-tab)" || firefox %s &
  Coq web site                : http://coq.inria.fr/
