coq-club - Re: [Coq-Club] Coercions and Defined Types
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coercions and Defined Types
  • Date: Fri, 2 Oct 2015 10:32:46 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gmalecha AT gmail.com; spf=Pass smtp.mailfrom=gmalecha AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f180.google.com
  • Ironport-phdr: 9a23:bZ2BGxWmEePEJOS5H84G23ExWzrV8LGtZVwlr6E/grcLSJyIuqrYZhOFt8tkgFKBZ4jH8fUM07OQ6PC8HzJcqs/Z7DgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2PJVsUz2PlPftbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN4xxd7FTDSwnPmYp/4Wr8ECbFUrcrkcbB04Ri1JjBxXPpEXxWY60uS/nvMJ83jObNIv4V+Zndy6l6vJEUhLnjz0Wfxsw9GzcisU42K1eqRasrBx264HRaYCRcvF5e/WOLpshWWNdU5MJBGR6CYSmYt5KVrJZMA==
Hi, Jason --
Thanks for the pointer. I think it would have worked, except my example a little bit more simplified since [a] and [b] need associated type class instances. So the type of [onEach] is really [forall a b, X a -> Y b -> foo a b -> bar a b]. Coq reports that this does not respect the uniform inheritence condition, which is in line with what is written in the manual.
On Thu, Oct 1, 2015 at 4:12 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
As a kludge, stick the definitions in a module, their types in a module type, declare the coercion in a functor, and then import the applied functor?
-Jason
On Oct 1, 2015 6:54 PM, "Gregory Malecha" <gmalecha AT gmail.com> wrote:
Hello --
I have some types (similar to):
Definition foo a b  := list a -> b.
Definition bar a b := a -> b.
and I have a function to transport [foo]s into [bar]s.
Definition onEach : forall a b, foo a b -> bar a b.
I want to declare [onEach] as a coercion:
Coercion onEach : foo >-> bar.
but I get
Error: Found target class bar instead of Funclass.
Is there some way to tell Coq that it should treat [bar] as opaque? I know that I can make [bar] a record type, but I don't really want to pack and unpack functions all the time.
Thanks.
gregory malecha
gregory malecha
