coq-club - Re: [Coq-Club] Coercions and Defined Types
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coercions and Defined Types
  • Date: Fri, 2 Oct 2015 14:40:21 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f181.google.com
  • Ironport-phdr: 9a23:aS/9rhEkkg9zK+y76C7F5p1GYnF86YWxBRYc798ds5kLTJ75o8WwAkXT6L1XgUPTWs2DsrQf27aQ7fyrADZRqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7z0pcGYOl8ZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzSqUdBzA7OShh78ry8BLHUAGn530GU2xQnAAeUCbf6xSvfJ7qtS2ymfB6wzLSac//VrcyVi6l9Lw6YBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
Are you looking for something like this?  (Initial idea courtesy of Georges Gonthier.)  Note that the typeclasses must be resolved (and resolvable) when defining the thing of type [foo a b].  Otherwise, you can define [k] of type [list a -> b], and then write [(k : foo a b) : bar a b].
(* your definitions *)
Class X (a : Type) : Type := {}.
Class Y (b : Type) : Type := {}.
Axiom onEach : forall a b, X a -> Y b -> (list a -> b) -> (a -> b).
Definition bar a b := a -> b.
(* abuse of typeclasses *)
Class foo_holder (a b : Type) := { foo : Type ; xa : X a ; yb : Y b ; good : foo = (list a -> b) }.
Arguments foo a b {_}.
Instance mk_foo a b (xa' : X a) (yb' : Y b) : foo_holder a b
  := {| foo := list a -> b ; xa := xa' ; yb := yb' ; good := eq_refl |}.
Coercion onEach' a b f (x : @foo a b f) : bar a b
  := onEach _ _ (@xa _ _ f) (@yb _ _ f) match @good _ _ f with
                                          | eq_refl => x
                                        end.
(* example *)
Global Instance: forall a, X a := {}.
Global Instance: forall a, Y a := {}.
Axiom a : Type.
Axiom b : Type.
Axiom k : foo a b.
Check k : bar a b.
On Fri, Oct 2, 2015 at 1:32 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:
Hi, Jason --
Thanks for the pointer. I think it would have worked, except my example a little bit more simplified since [a] and [b] need associated type class instances. So the type of [onEach] is really [forall a b, X a -> Y b -> foo a b -> bar a b]. Coq reports that this does not respect the uniform inheritence condition, which is in line with what is written in the manual.
On Thu, Oct 1, 2015 at 4:12 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
As a kludge, stick the definitions in a module, their types in a module type, declare the coercion in a functor, and then import the applied functor?
-Jason
On Oct 1, 2015 6:54 PM, "Gregory Malecha" <gmalecha AT gmail.com> wrote:
Hello --
I have some types (similar to):
Definition foo a b  := list a -> b.
and I have a function to transport [foo]s into [bar]s.
Definition onEach : forall a b, foo a b -> bar a b.
I want to declare [onEach] as a coercion:
Coercion onEach : foo >-> bar.
but I get
Error: Found target class bar instead of Funclass.
Is there some way to tell Coq that it should treat [bar] as opaque? I know that I can make [bar] a record type, but I don't really want to pack and unpack functions all the time.
Thanks.
gregory malecha
gregory malecha
