coq-club - Re: [Coq-Club] Proof generals, coqdep and 8.5
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Proof generals, coqdep and 8.5
  • Date: Thu, 29 Oct 2015 08:43:59 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f169.google.com
  • Ironport-phdr: 9a23:q1EwERXAx3hEG9xO383DT2xekz7V8LGtZVwlr6E/grcLSJyIuqrYZhKBt8tkgFKBZ4jH8fUM07OQ6PC9HzVQqs/d+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8CVOlUD3Wb1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GPZTCy1jOGQo7uXqswPCRE2B/DFUBm4Ri19DBxXPxBD8RJb49CXg4LlTwi6faPX3QKouVHyJ6LpxVB7llW9TLz806nvazMd3kbhHoR+8jxN6yo/QJoqSMawtLevmYdoGSD8ZDY5qXCtbD9bkYg==
Hi, it should be compatible. How do you give arguments to coqtop in Proofgeneral? Are you sure it is not using -I? Maybe a "file variable" not updated?
The recommended way of setting coqtop options in pg is now via the _CoqProject file.
Best
Pierre Courtieu
Le mercredi 28 octobre 2015, Yannick <yannick.zakowski AT irisa.fr> a écrit :
Dear all,
Following my previous question, I switched to the 8.5b2. I however have
an issue with coqdep: it seems that the behaviour of the -I option has
changed.
Having a file foo.v, and a Require Import foo. in another file bar.v,
the following command now fails:
coqdep -I . bar.v
But it now works with a -Q or -R option.
However, it seems that Proof General did not adapt to this change, since
trying to interpret the Require Import calls coqdep with -I and fails.
What is a bit more surprising is that it seems that this has been
considered since a change to the function "coq-find-project-file" in the
coq.el file has been made to remove any use of the obsolete -I -as
option, in the 4.3pre150930 version.
Hence the question: am I missing something or was the change partial and
is Proof General currently incompatible with Coq 8.5b2?
Thanks for your help,
Best,
Yannick
