- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proof generals, coqdep and 8.5
- Date: Thu, 29 Oct 2015 09:35:35 +0100
Dear John and Pierre,
If I am not mistaken, I believe the current working directory used to be
handled by default, hence I did not use to have a _CoqProject file. But
you are indeed right that it is just what I needed.
Thanks a lot for the help,
Best,
Yannick Zakowski
Le 29/10/2015 08:43, Pierre Courtieu a écrit :
> Hi, it should be compatible. How do you give arguments to coqtop in
> Proofgeneral? Are you sure it is not using -I? Maybe a "file variable"
> not updated?
> The recommended way of setting coqtop options in pg is now via
> the _CoqProject file.
> Best
> Pierre Courtieu
> Le mercredi 28 octobre 2015, Yannick
> <yannick.zakowski AT irisa.fr
> <mailto:yannick.zakowski AT irisa.fr>>
> a écrit :
> Dear all,
> Following my previous question, I switched to the 8.5b2. I however have
> an issue with coqdep: it seems that the behaviour of the -I option has
> changed.
> Having a file foo.v, and a Require Import foo. in another file bar.v,
> the following command now fails:
> coqdep -I . bar.v
> But it now works with a -Q or -R option.
> However, it seems that Proof General did not adapt to this change, since
> trying to interpret the Require Import calls coqdep with -I and fails.
> What is a bit more surprising is that it seems that this has been
> considered since a change to the function "coq-find-project-file" in the
> coq.el file has been made to remove any use of the obsolete -I -as
> option, in the 4.3pre150930 version.
> Hence the question: am I missing something or was the change partial and
> is Proof General currently incompatible with Coq 8.5b2?
> Thanks for your help,
> Best,
> Yannick
- [Coq-Club] Proof generals, coqdep and 8.5, Yannick, 10/28/2015
- Re: [Coq-Club] Proof generals, coqdep and 8.5, John Wiegley, 10/28/2015
- Re: [Coq-Club] Proof generals, coqdep and 8.5, Pierre Courtieu, 10/29/2015
- Re: [Coq-Club] Proof generals, coqdep and 8.5, Yannick, 10/29/2015
