coq-club - [Coq-Club] Surprising unification heuristics
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Cc: Matthieu Sozeau <mattam AT mattam.org>
  • Subject: [Coq-Club] Surprising unification heuristics
  • Date: Fri, 30 Oct 2015 12:29:21 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:mimpGxLdZnggGCjdltmcpTZWNBhigK39O0sv0rFitYgULvnxwZ3uMQTl6Ol3ixeRBMOAu68C0bOd4/yocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLtjqvip9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6k4voZX2MKpSJJH02AxxXzQ5v8tmOuve5w3SScIYvuTKwcVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
Hi coq-club,
I'm slightly puzzled by the behaviour of unification in the following script
(tested in 8.4pl4 and trunk):
Goal forall (a: bool), exists b, a = b.
Proof.
intros a; eexists.
destruct a.
(* Two goals: [true = ?6] and [false = ?6] *)
apply eq_refl.
(* One goal: [false = false] *)
Abort.
Instead of [false = false], I expected the second goal to become [false =
true]. Unifying explicitly, instead of applying [eq_refl], yields similar
results (this example courtesy of my labmate CJ):
Proof.
intros a; eexists.
destruct a.
match goal with |- _ = ?x => unify x true end.
(* Two goals: [true = true] and [false = false] *)
Abort.
What seems to happen is that Coq remembers that [a] was destructed into
[true] in the first branch, and silently replaces [true] by [a] (taken from
the evar's context) when unifying (thus yielding [false] in the second
branch). This behaviour is biting me in a larger example, which boils down to
this:
Definition f (a b: list nat) :=
match b with
| nil => True
| _ => False
end.
Lemma f_nil : f nil nil.
Proof I.
Goal forall (a: list nat), exists b, f a b.
Proof.
eexists.
induction a.
apply f_nil.
(* Unprovable: the [nil] that comes from applying [f_nil] shouldn't
have been rewritten to [a] in the inductive case *)
Is this considered a bug, or a feature? And is this behaviour still present
in Beta's and Matthieu's new unification algorithm?
Cheers,
Clément.
Attachment: signature.asc
Description: OpenPGP digital signature
