coq-club - Re: [Coq-Club] Surprising unification heuristics
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Surprising unification heuristics
  • Date: Fri, 30 Oct 2015 12:48:23 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f45.google.com
  • Ironport-phdr: 9a23:VGGIPhFIvYjv2VKYAs8RIp1GYnF86YWxBRYc798ds5kLTJ75pMWwAkXT6L1XgUPTWs2DsrQf27eQ6fmrCDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niqbootaCO01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4+VWMfjhpBBUDh4RDkU5Ht+n/4sex82ySeMMDeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
Clément,
The unification heuristics involving evar instances is a feature, although not a perfect one. There are (at least) two reported bugs against it: 3141 and 3918. Both still exist in recent 8.5 (I'm using 7bf9bbe).
I have been bitten by both cases (a bad heuristic [3918], and unification prevented due to lack of a heuristic [3141]).
-- Jonathan
On 10/30/2015 12:29 PM, Clément Pit--Claudel wrote:
Hi coq-club,
I'm slightly puzzled by the behaviour of unification in the following script
(tested in 8.4pl4 and trunk):
Goal forall (a: bool), exists b, a = b.
Proof.
intros a; eexists.
destruct a.
(* Two goals: [true = ?6] and [false = ?6] *)
apply eq_refl.
(* One goal: [false = false] *)
Abort.
Instead of [false = false], I expected the second goal to become [false =
true]. Unifying explicitly, instead of applying [eq_refl], yields similar
results (this example courtesy of my labmate CJ):
Proof.
intros a; eexists.
destruct a.
match goal with |- _ = ?x => unify x true end.
(* Two goals: [true = true] and [false = false] *)
Abort.
What seems to happen is that Coq remembers that [a] was destructed into
[true] in the first branch, and silently replaces [true] by [a] (taken from
the evar's context) when unifying (thus yielding [false] in the second
branch). This behaviour is biting me in a larger example, which boils down to
this:
Definition f (a b: list nat) :=
match b with
| nil => True
| _ => False
end.
Lemma f_nil : f nil nil.
Proof I.
Goal forall (a: list nat), exists b, f a b.
Proof.
eexists.
induction a.
apply f_nil.
(* Unprovable: the [nil] that comes from applying [f_nil] shouldn't
have been rewritten to [a] in the inductive case *)
Is this considered a bug, or a feature? And is this behaviour still present
in Beta's and Matthieu's new unification algorithm?
Cheers,
Clément.
