coq-club - Re: [Coq-Club] automating forward chaining
  • From: Clément Pit--Claudel <clement.pit AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] automating forward chaining
  • Date: Thu, 5 Nov 2015 01:03:08 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23:XqdHkhJ9aqTNbm/wKtmcpTZWNBhigK39O0sv0rFitYgULvnxwZ3uMQTl6Ol3ixeRBMOAu68C0LOd4vuocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLsjqvjoNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6k4voZX2MKpSJJH02AxxXzQ5v8tmOuve5w3SScIYvuTKwcVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
Hi Jonathan,
In my current project I use the following tactic as an alternative to pose
proof (simplified):
Inductive Learnt {A: Type} (a: A) :=
| AlreadyKnown : Learnt a.
Ltac learn fact :=
lazymatch goal with
| [ H: Learnt fact |- _ ] => fail 0 "fact" fact "already learnt"
| _ => pose proof (AlreadyKnown fact); pose proof fact
end.
Instead of looking for duplicates in the context, [learn] explicitly records
each call, ensuring that work can't be duplicated (see below for a slightly
better tactic). This solves the problem that you described of destruction
causing loops; here's an example that will get in a loop with [pose proof],
even after using [fail_if_redundant]:
Parameter P : nat -> Prop.
Parameter Q R : nat -> nat -> Prop.
Axiom P_Q : forall {x}, P x -> exists y, Q x y.
Axiom Q_R : forall {x y}, P x -> Q x y -> R y x.
Goal forall x, P x -> exists y, R y x.
Proof.
repeat match goal with
| _ => progress intros
| [ H: _ /\ _ |- _ ] => destruct H
| [ H: exists _, _ |- _ ] => destruct H
| [ H: P _ |- _ ] => learn (P_Q H)
| [ H: P ?x, H': Q ?x _ |- _ ] => learn (Q_R H H')
| [ |- exists _, _ ] => eexists
| _ => eassumption
end.
Qed.
This approach feels very SMT-y to me (if suffers from similar pitfalls, too,
such as matching loops arising from axioms such that [forall x, P x -> exists
y, P y]); it works well for complex top-down proofs where eauto isn't
sufficiently fast or flexible, but it does tend to create large goals with
many hypotheses.
Cheers,
Clément.
[1] The full tactic actually looks more like this:
Ltac learn fact :=
lazymatch goal with
| [ H: Learnt fact |- _ ] => fail 0 "fact" fact "has already been
learnt"
| _ => let type := type of fact in
lazymatch goal with
| [ H: @Learnt type _ |- _ ] => fail 0 "fact" fact "of type" type
"was already learnt through" H
end
end.
On 11/04/2015 09:29 PM, Jonathan Leivent wrote:
> Could a type of automation hint be added to Coq that helps with forward
> chaining?
> Of course, (e)auto Extern hints are general enough to be used to do forward
> chaining. One can write something like this:
> Hint Extern 10 => match goal with H : T |- _=> pose proof (Lem H) end.
> so that during (e)auto, whenever a hypothesis of type T is present, the
> automation will add a new hypothesis based on lemma Lem. However, this
> slows automation significantly, because nothing stops it from adding
> duplicates of that new hypothesis, with these duplicates needlessly adding
> to the backtracking strain. Also, this only produces one parameterization
> of Lem, not all of them.
> It's possible to do this instead:
> Hint Extern 10 => repeat match goal with H : T |- _=> let H':=fresh in pose
> proof (Lem H) as H'; fail_if_redundant H' end.
> where fail_if_redundant (see below) checks to see if another hyp with the
> same type as H' already exists, and fails if one does. This produces all
> parameterizations of Lem without duplicates, but slows automation a lot due
> to repeated useless attempts at firing this hint, and the internal
> backtracking for duplicate prevention. Also, if some further (e)auto
> processing of the goal purposefully removed one such new hypothesis (by
> some elimination - like destruct), this hint would make it re-materialize,
> perhaps causing even more costly needless proof searching to get triggered.
> The problem is that there is currently no way to trigger an action to occur
> only when a new hypothesis of a certain type is added to a goal. But
> suppose there was such a mechanism. The interface might look like this:
> Hint FChain (H : T) => pose proof (Lem H).
> The semantics would be - during (e)auto, if a new hypothesis H with a type
> matching the type pattern T is added to the goal, then trigger the rhs
> tactic of each applicable FChain hint immediately after the completion of
> the hint that added H. The same hint wouldn't get triggered twice for the
> same hypothesis. It might make sense to add a cost to each FChain hint,
> which would delay the triggering of that FChain hint until just before
> other non-FChain hints of similar cost - so that the general form would be:
> Hint FChain <cost> <hyp pattern> => <tactic> : <dbs>.
> For hypotheses that already exist in the goal at the time the (e)auto
> tactic is started, they are all considered new, and so all will trigger any
> applicable FChain hints. One could also have a tactic [autofchain with
> dbs] that, like autounfold and autorewrite, used the hints outside the
> context of (e)auto.
> Does a feature like this sound useful?
> Maybe typeclasses might be able to do things similar to this, but I'm no
> typeclass expert. Do any typeclass experts know if (and how) it can?
> -- Jonathan
> Note:
> Ltac fail_if_redundant H :=
> let T:=type of H in
> try (clear H; lazymatch goal with _: T |- _ => fail 1 | _ => fail end).
Attachment: signature.asc
Description: OpenPGP digital signature
