coq-club - Re: [Coq-Club] automating forward chaining
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] automating forward chaining
  • Date: Thu, 5 Nov 2015 11:01:35 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f173.google.com
  • Ironport-phdr: 9a23:SeGrChD7rBlaUXymNJZ5UyQJP3N1i/DPJgcQr6AfoPdwSP74rsbcNUDSrc9gkEXOFd2CrakU1qyN7uu6AyQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTqkbvvsMeJKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1kbVGwKkhNOSyzI7Q/3WIu55in9sOt+1S2XMOX5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
Hi Clément,
I have tried variants of your proposal, but I don't like the additional note-taking hypotheses - both because they complicate the goals, and because they create dependencies between hypotheses that can cause other tactics to fail when they try to eliminate or alter depended-on hypotheses.
Also, having Extern hints that use the learn tactic means that they will be triggered much more often than needed, in most cases just failing after doing their search for Learnt hyps - which slows down (e)auto.
My proposal is just that - if ad-hoc workarounds for this deficiency are common, but they all suffer similar drawbacks - maybe the better solution is to provide the missing ingredient in some way. And the missing ingredient seems to be the ability to automatically trigger a tactic after a new hypothesis of some type is added to a goal (also perhaps when the type of an existing hypothesis changes).
-- Jonathan
On 11/05/2015 01:03 AM, Clément Pit--Claudel wrote:
Hi Jonathan,
In my current project I use the following tactic as an alternative to pose
proof (simplified):
Inductive Learnt {A: Type} (a: A) :=
| AlreadyKnown : Learnt a.
Ltac learn fact :=
lazymatch goal with
| [ H: Learnt fact |- _ ] => fail 0 "fact" fact "already learnt"
| _ => pose proof (AlreadyKnown fact); pose proof fact
end.
Instead of looking for duplicates in the context, [learn] explicitly records
each call, ensuring that work can't be duplicated (see below for a slightly
better tactic). This solves the problem that you described of destruction
causing loops; here's an example that will get in a loop with [pose proof],
even after using [fail_if_redundant]:
Parameter P : nat -> Prop.
Parameter Q R : nat -> nat -> Prop.
Axiom P_Q : forall {x}, P x -> exists y, Q x y.
Axiom Q_R : forall {x y}, P x -> Q x y -> R y x.
Goal forall x, P x -> exists y, R y x.
Proof.
repeat match goal with
| _ => progress intros
| [ H: _ /\ _ |- _ ] => destruct H
| [ H: exists _, _ |- _ ] => destruct H
| [ H: P _ |- _ ] => learn (P_Q H)
| [ H: P ?x, H': Q ?x _ |- _ ] => learn (Q_R H H')
| [ |- exists _, _ ] => eexists
| _ => eassumption
end.
Qed.
This approach feels very SMT-y to me (if suffers from similar pitfalls, too,
such as matching loops arising from axioms such that [forall x, P x -> exists
y, P y]); it works well for complex top-down proofs where eauto isn't
sufficiently fast or flexible, but it does tend to create large goals with many
hypotheses.
Cheers,
Clément.
[1] The full tactic actually looks more like this:
Ltac learn fact :=
lazymatch goal with
| [ H: Learnt fact |- _ ] => fail 0 "fact" fact "has already been
learnt"
| _ => let type := type of fact in
lazymatch goal with
| [ H: @Learnt type _ |- _ ] => fail 0 "fact" fact "of type" type
"was already learnt through" H
end
end.
