coq-club - Re: [Coq-Club] Similarities between forall and fun
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Similarities between forall and fun
  • Date: Mon, 16 Nov 2015 12:50:54 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=freek AT cs.ru.nl; spf=None smtp.mailfrom=freek AT cs.ru.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
  • Ironport-phdr: 9a23:FW7X0BDZn9H+QOJklwCfUyQJP3N1i/DPJgcQr6AfoPdwSP74psbcNUDSrc9gkEXOFd2CrakU1qyL7Ou7ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTqkb3tsMaLKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1UGX2gV2iVJDgTE7hKyCpnrvyb5nuFmnjOHe8vyG+NnEQ++5rtmHUe7wBwMMCQ0pTna
Hi Thorsten,
>What is nice about this conceptual confusion?
That you can get away with it? That you can simplify your
syntax and typing rules that way and still have a viable
logical framework?
The "[x:A]" binder of automath should not be thought of
as creating a function or function type. It is "just"
a notion of binding a variable, to be able to do HOAS.
I'm not saying that the Automath approach to type theory
is more powerful than the "modern" one (it's basically an
alternative to LF), but it _is_ simpler and more regular
and it _does_ work.
Freek
