coq-club - RE: [Coq-Club] Similarities between forall and fun
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Similarities between forall and fun
  • Date: Mon, 16 Nov 2015 14:36:58 +0000
  • Accept-language: de-DE, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=michael.soegtrop AT intel.com; spf=Pass smtp.mailfrom=michael.soegtrop AT intel.com; spf=None smtp.helo=postmaster AT mga11.intel.com
  • Ironport-phdr: 9a23:DbjAchcvQ/YCHSzdXqjlmm4glGMj4u6mDksu8pMizoh2WeGdxc69ZR7h7PlgxGXEQZ/co6odzbGG7ua9BideuN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvcCMKFsRzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePFyRrtBST8iLmod5cvxtBCFQxHFri8XVXxTmR5VCSDE6gv7V9H/qH2pmPB63XzQBsr7QqwuXizmp4JqQx/hhSNNf2o88WrXg8F0yrlcrR29vRtn64/SfIyRcvF5e/WOLpshWWNdU5MJBGR6CYSmYt5XAg==
Dear Yasuaki,
I’m currently studying COQ (well taking a long time…) and have noticed similarities between forall (dependent product?) and function terms.
actually in Coq I would think they are the same, not just similar. It is interesting to look at function types with notation switched off (View Menu in CoqIDE):
Definition add (a b : nat) := a+b.
Check add.
With notation switched on, you get this:
add
     : nat -> nat -> nat
Wit notation switched off, you get this:
add
     : forall (_ : nat) (_ : nat), nat
Likewise you get for
Lemma add' : forall (a b : nat), nat.
  intros a b. exact (a+b).
Defined.
Check add'.
with notations switched on the type
add'
     : nat -> nat -> nat
So as it looks, in Coq -> is just a notation for forall for cases where the result type does not depend on the arguments.
Best regards,
Michael
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
