coq-club - Re: [Coq-Club] renaming in inversion tactic
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] renaming in inversion tactic
  • Date: Sun, 22 Nov 2015 07:28:24 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=adamc AT csail.mit.edu; spf=Pass smtp.mailfrom=adamc AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing.csail.mit.edu
  • Ironport-phdr: 9a23:Hq0zIRAbO2/0K0y8H9SdUyQJP3N1i/DPJgcQr6AfoPdwSP74ocbcNUDSrc9gkEXOFd2CrakU1qyI4+u7CSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTqkb7isMaDKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1IQW2BeuRpMAhDM6BiyCp79uy7xnuFm0Siee8j3UfY5VSn0vPQjcwPhlCpSb21xy2rQkMEl1K8=
I don't think this is just an issue with fiddly behavior of the inversion tactic. You couldn't prove the same theorem on paper with a single inversion, either. You need induction.
The definition of [ctx_cons] allows multiple derivations of the same fact. The nondeterminism comes from the order in which you consider the variables.
So, the particular [ctx_cons] derivation you have as a hypothesis may not consider variable [x] "last."
On 11/22/2015 03:27 AM, Flávio Leonardo Cavalcanti de Moura wrote:
Hi there,
I am trying to prove a property that should be straightforward, but due
to a kind of renaming of the inversion tactic, I don't know how to complete
the
proof. I am doing an adaptation of B. Pierce SF course, in which contexts (for
cbv simply typed lambda calculus) are
defined as follows:
Definition partial_map (A:Type) := var -> option A.
Definition empty {A:Type} : partial_map A := (fun _ => None).
Definition extend {A:Type} (Gamma : partial_map A) (x:var) (T : A) :=
fun x' => if eq_var_dec x x' then Some T else Gamma x'.
Definition context := partial_map ty.
I want to prove subject reduction for the (general) simply typed lambda
calculus,
so I defined consistency of contexts as follows:
Inductive ctx_cons: context -> Prop :=
| empty_cons: ctx_cons empty
| nempt_cons: forall Gamma x U, ctx_cons Gamma -> Gamma x = None -> ctx_cons
(extend Gamma x U).
Now I want to prove that:
Lemma subctx_cons: forall (Gamma:context) (x:var) (U:ty), ctx_cons (extend Gamma
x U) -> ctx_cons Gamma.
It should be straightforward by inversion tactic on the hypothesis H:
ctx_cons (extend Gamma x U), but instead of getting as hypothesis
ctx_cons Gamma, coq generates the following for the second case of the
definition:
Gamma : context
x : var
U : ty
H : ctx_cons (extend Gamma x U)
Gamma0 : context
x0 : var
U0 : ty
H1 : ctx_cons Gamma0
H2 : Gamma0 x0 = None
H0 : extend Gamma0 x0 U0 = extend Gamma x U
ctx_cons Gamma
I don't see how to prove, for instance, that Gamma = Gamma0 because they
don't need to be syntactic the same...
Thanks in advance for any help.
Best regards,
Flávio.
