coq-club - Re: [Coq-Club] renaming in inversion tactic
  • From: flaviomoura AT unb.br (Flávio Leonardo Cavalcanti de Moura)
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] renaming in inversion tactic
  • Date: Fri, 27 Nov 2015 23:23:45 -0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=flaviomoura AT unb.br; spf=Pass smtp.mailfrom=flaviomoura AT unb.br; spf=None smtp.helo=postmaster AT mxb.unb.br
  • Ironport-phdr: 9a23:jYIFyByQjVc/Hg7XCy+O+j09IxM/srCxBDY+r6Qd0e8RIJqq85mqBkHD//Il1AaPBtWGraIYwLGG+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU35j8jLD60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVHSODxe7kyZb1eFjUvdW4vt+PxshyWQw+G+HobV2ILiBNgHg7PqhvgFtfftqLkt+01/CSdO8TsQbd8cj285qNgQRn0iW8LOnYc93zNg40j3+pgvBu9qkknkMbva4aPOa8mcw==
Dear Cedric and Adam,
Thank you very much for your comments. In fact, working with an inductively
defined context (instead of a partial function) allows such a
straightforward proof by inversion that I had in mind. Therefore, the
nondeterminism
mostly comes from the non-inductive structure of the context, and
therefore extend is not invertible and Coq cannot infer that a context is
either empty or (extend Gamma x U) for some Gamma, x and U.
Best regards,
Flávio.
Inductive context :=
| ctx_empty : context
| ctx_extend : context -> var -> ty -> context.
Fixpoint eval (c: context) (y: var): option ty :=
match c with
| ctx_empty => None
| ctx_extend pm' x T => if eq_var_dec x y then Some T else eval pm' y
end.
Inductive ctx_cons: context -> Prop :=
| empty_cons: ctx_cons ctx_empty
| nempt_cons: forall Gamma x U, ctx_cons Gamma -> eval Gamma x = None ->
ctx_cons (ctx_extend Gamma x U).
Lemma subctx_cons: forall Gamma x U, ctx_cons (ctx_extend Gamma x U) ->
ctx_cons Gamma.
Proof.
intros Gamma x U H.
inversion H; subst. assumption.
Qed.
Cedric Auger
<sedrikov AT gmail.com>
writes:
> 2015-11-22 9:27 GMT+01:00 Flávio Leonardo Cavalcanti de Moura
> <flaviomoura AT unb.br>:
> Hi there,
> I am trying to prove a property that should be straightforward,
> but due
> to a kind of renaming of the inversion tactic, I don't know how to
> complete the
> proof. I am doing an adaptation of B. Pierce SF course, in which
> contexts (for
> cbv simply typed lambda calculus) are
> defined as follows:
> Definition partial_map (A:Type) := var -> option A.
> Definition empty {A:Type} : partial_map A := (fun _ => None).
> Definition extend {A:Type} (Gamma : partial_map A) (x:var) (T : A)
> fun x' => if eq_var_dec x x' then Some T else Gamma x'.
> Definition context := partial_map ty.
> I want to prove subject reduction for the (general) simply typed
> lambda calculus,
> so I defined consistency of contexts as follows:
> | empty_cons: ctx_cons empty
> | nempt_cons: forall Gamma x U, ctx_cons Gamma -> Gamma x = None -
> > ctx_cons (extend Gamma x U).
> Now I want to prove that:
> Lemma subctx_cons: forall (Gamma:context) (x:var) (U:ty), ctx_cons
> (extend Gamma x U) -> ctx_cons Gamma.
> It should be straightforward by inversion tactic on the hypothesis
> H:
> ctx_cons (extend Gamma x U), but instead of getting as hypothesis
> ctx_cons Gamma, coq generates the following for the second case of
> the definition:
> Gamma : context
> x : var
> U : ty
> H : ctx_cons (extend Gamma x U)
> Gamma0 : context
> x0 : var
> U0 : ty
> H1 : ctx_cons Gamma0
> H2 : Gamma0 x0 = None
> H0 : extend Gamma0 x0 U0 = extend Gamma x U
> ctx_cons Gamma
> I don't see how to prove, for instance, that Gamma = Gamma0
> because they
> don't need to be syntactic the same...
> Thanks in advance for any help.
> Best regards,
> Flávio.
> ​I do not think this is provable in Coq.
> Adam said that you need at least induction, but in fact, even with
> induction​, I doubt you can prove it.
> Although what follows is not a proof of the fact that it is
> unprovable, I hope to convince you, that, at least, it is not as
> trivial as it seems.
> Consider var=unit and A=bool, to simplify.
> Now, we have 3 possible partial_map (assuming functionnal
> extensionnality):
> pm_bot := fun _ => None (* pm_bot = empty *)
> pm_true := fun _ => Some true
> pm_false := fun _ => Some false
> Always assuming functionnal extensionnality, we have: "extend pm_bot
> tt true = extend pm_false tt true = extend pm_true tt true".
> Thus, "P := nempt_cons pm_bot tt true empty_cons (eq_refl None)" is a
> proof of "ctx_cons (extend pm_bot tt true)".
> Thus it is also a proof of "ctx_cons (extend pm_false tt true)".
> Now, you can see your previous context as:
> ​​ pm_false : context
> tt : var
> true : ty
> P : ctx_cons (extend pm_false tt true)
> pm_bot : context
> tt : var
> true : ty
> empty_cons : ctx_cons pm_bot
> eq_refl None : pm_bot tt = None
> extensionnality … : extend pm_bot tt true = extend pm_false tt true
> ctx_cons pm_false
> As you can see, you end up with Gamma0 different from Gamma.
> Of course, "ctx_cons pm_false" remains provable, but with a direct
> construction, not the inversion.
> Indeed, what you had in mind was that at this point you should have
> "Gamma = pm_bot", which is not necessarily the case here.
> In a more general setting where var is not simply unit, and A not
> simply bool, things can be even more complex, and I suspect them not
> to be always provable.
> Well, I assumed functionnal extensionnality. This axiom is often
> assumed to be consistent with Coq without any additionnal axiom.
> The point is that with such an axiom, extend is not inversible, you
> can have several extension leading to the same partial map.
> Inversion tactic works mainly when your data types are inductives.
> For instance, if you had defined partial_map as:
> Inductive partial_map (A : Type) :=
> | pm_empty : partial_map A
> | pm_extend : var -> A -> partial_map A -> partial_map A.
> and coerce its evaluation with
> Definition eval (A : Type) : partial_map A -> var -> option A :=
> fix eval_ pm :=
> match pm with
> | pm_empty => fun _ => None
> | pm_extend x v pm => fun y => if eq_var_dec x y then Some v else
> eval_ pm y
> end.
> Then for the same reasons as previously, you could not prove easily:
> where "extend" is your own definition applied to "@eval A Gamma"
> instead of Gamma.
> Still, you could prove
> ​​Lemma subctx_cons: forall (Gamma:context) (x:var) (U:ty), ctx_cons2
> (pm_extend Gamma x U) -> ctx_cons2 Gamma.
> ​Inductive ctx_cons2: context -> Prop :=
> | empty_cons: ctx_cons pm_empty
> | nempt_cons: forall Gamma x U, ctx_cons2 Gamma -> eval Gamma x = None
> -> ctx_cons2 (pm_extend Gamma x U).
> Simply because this time, pm_extend is injective (given Gamma x and U,
> there is only one Gamma0 x0 and U0 such that pm_extend Gamma x U =
> pm_extend Gamma0 x0 U0).
