coq-club - Re: [Coq-Club] tracing extracted code
  • From: Frédéric Besson <frederic.besson AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] tracing extracted code
  • Date: Tue, 24 Nov 2015 19:32:54 +0100
Hello,
Do not worry for my soul, I won’t be doomed : I fear no evil.
Being pragmatic is a shortcut not a shortcoming!
I am familiar with monads — turning an existing code in monadic style for the
only purpose of tracing/logging would be a waste of time.
The proposal of matej makes sense but I feel that some axiomatisation of the
Trace function would be necessary.
I was proposed other solutions from teammates:
In the Verasco project, they add a fake dependancy and limit inlining.
It is also possible to patch the extraction of a « tracer » function— with
some notations it looks non intrusive.
BTW, I am curious about what could really go wrong ?
What kind of Coq property can be broken — by an axiom of the form :
Axiom IAmAnyTypeSafeOCamlProgram : A -> unit with the additional assumption
that A is a ML type.
I see that this code could raise an exception or abort the Coq program — does
not sound so bad.
If A is polymorphic and is used in OCaml with some mutable data-structure,
anything could happen — this sounds bad.
Other scenarios ?
Thanks,
Frédéric
> On 23 Nov 2015, at 17:43, Cedric Auger
> <sedrikov AT gmail.com>
> wrote:
> ​There is no side effect in Coq, assuming extraction will manage side
> effects is wrong.
> (Think of extraction to Haskell which has no side effect, unless you do
> really dirty things.)
> If your real code uses side effect, then you loose most of the point of
> having done your proofs in Coq.
> Still, you are not doomed, as you can rely on some tricks, like monads (if
> you do not know anything about monads, you should probably read a little
> about them, it could be useful to solve your problem).
> Declare a constant of type "state -> nat -> state", and pass sequentially
> all your states to your functions.
> Then implement "state" with what ever you want.
> Parameter state : Type.
> Definition sequence := state -> state.
> Parameter trace_nat : nat -> sequence.
> (* print all nats from n to 0 *)
> Definition count_down​ : nat -> sequence :=
> fix count_down (n : nat) : sequence :=
> match n with
> | O => trace_nat O
> | S n => fun s =>
> let s := trace_nat (S n) in
> count_down n s
> end.
> ​And then for you extracted code, you can do a side effect with
> implementing "state" with "unit",
> and "trace_nat : nat -> unit -> unit" (ok there is one "unit" more) as "fun
> n () => print_nat n".
> Of course, your "main" function will have an extra "unit" parameter.
> That should solve your problem, as with that, the state must be kept and
> follow some path from "inputs" to "outputs".
> Being abstract, the extraction cannot optimize anything on it, and must be
> keep the result.
> This also ensure sequential execution of all your "side effect" stuff.
> You can even simply not implement "state" with a side effect, but with a
> list of natural numbers.
> Then you could run your "main" program with the empty list, and then print
> the whole list as result (but storing the list might take a lot of space).
Attachment: signature.asc
Description: Message signed with OpenPGP using GPGMail
