- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] tracing extracted code
- Date: Wed, 25 Nov 2015 02:44:18 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sedrikov AT gmail.com; spf=Pass smtp.mailfrom=sedrikov AT gmail.com; spf=None smtp.helo=postmaster AT mail-ig0-f170.google.com
- Ironport-phdr: 9a23:xPFmfBN+k4L8CCrM4kUl6mtUPXoX/o7sNwtQ0KIMzox0KPn9rarrMEGX3/hxlliBBdydsKIZzbWJ+Pu9EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35nxiL/5oMCbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBO/xeL19RrhFBhwnNXo07Yvlr1OLGQCI/z4XVngcuhtOGQnMqh/gCMTfqCz/48Fw1DObNoXfUL85Q3z29KpnUh7rjzkvODsw8WWRgct12vEI6Cm9rgByltaHKLqeM+BzK/vQ
2015-11-24 19:32 GMT+01:00 Frédéric Besson <frederic.besson AT inria.fr>:
Hello,
Do not worry for my soul, I won’t be doomed : I fear no evil.
Being pragmatic is a shortcut not a shortcoming!
I am familiar with monads — turning an existing code in monadic style for the only purpose of tracing/logging would be a waste of time.
The proposal of matej makes sense but I feel that some axiomatisation of the Trace function would be necessary.
I was proposed other solutions from teammates:
In the Verasco project, they add a fake dependancy and limit inlining.
It is also possible to patch the extraction of a « tracer » function— with some notations it looks non intrusive.
BTW, I am curious about what could really go wrong ?
What kind of Coq property can be broken — by an axiom of the form :
Axiom IAmAnyTypeSafeOCamlProgram : A -> unit with the additional assumption that A is a ML type.
Such an axiom has no problem on the Coq side. After all, there is a function which does this in Coq (fun _ => tt), and the problems you can encounter when implementing it are not bound to the unit type. With Ocaml, as soon as you have a _ -> _ some side effect can occur.
I see that this code could raise an exception or abort the Coq program — does not sound so bad.
If A is polymorphic and is used in OCaml with some mutable data-structure, anything could happen — this sounds bad.
Other scenarios ?
You do not need A polymorphic, you could also have A as an Àxiom A : Type. Which would then be implemented by a type with mutable fields.
You could also have A=unit, with a side effect on a global mutable variable, which would break things.
For instance in Ocaml, you could have a "get_counter : unit -> int", "inc_counter : unit -> unit" and some extracted code using these functions.
"inc_counter" could seem completely harmless, but it could in fact hide something more harmful.
Thanks,
Frédéric
> On 23 Nov 2015, at 17:43, Cedric Auger <sedrikov AT gmail.com> wrote:
> There is no side effect in Coq, assuming extraction will manage side effects is wrong.
> (Think of extraction to Haskell which has no side effect, unless you do really dirty things.)
> If your real code uses side effect, then you loose most of the point of having done your proofs in Coq.
> Still, you are not doomed, as you can rely on some tricks, like monads (if you do not know anything about monads, you should probably read a little about them, it could be useful to solve your problem).
> Declare a constant of type "state -> nat -> state", and pass sequentially all your states to your functions.
> Then implement "state" with what ever you want.
> Parameter state : Type.
> Definition sequence := state -> state.
> Parameter trace_nat : nat -> sequence.
> (* print all nats from n to 0 *)
> Definition count_down : nat -> sequence :=
> fix count_down (n : nat) : sequence :=
> match n with
> | O => trace_nat O
> | S n => fun s =>
> let s := trace_nat (S n) in
> count_down n s
> end.
> And then for you extracted code, you can do a side effect with implementing "state" with "unit",
> and "trace_nat : nat -> unit -> unit" (ok there is one "unit" more) as "fun n () => print_nat n".
> Of course, your "main" function will have an extra "unit" parameter.
> That should solve your problem, as with that, the state must be kept and follow some path from "inputs" to "outputs".
> Being abstract, the extraction cannot optimize anything on it, and must be keep the result.
> This also ensure sequential execution of all your "side effect" stuff.
> You can even simply not implement "state" with a side effect, but with a list of natural numbers.
> Then you could run your "main" program with the empty list, and then print the whole list as result (but storing the list might take a lot of space).
- [Coq-Club] tracing extracted code, Frédéric Besson, 11/23/2015
- Re: [Coq-Club] tracing extracted code, Matěj Grabovský, 11/23/2015
- Re: [Coq-Club] tracing extracted code, Cedric Auger, 11/23/2015
- Re: [Coq-Club] tracing extracted code, Frédéric Besson, 11/24/2015
- Re: [Coq-Club] tracing extracted code, Cedric Auger, 11/25/2015
