- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Local Universes in Sections?
- Date: Fri, 27 Nov 2015 10:26:24 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gmalecha AT gmail.com; spf=Pass smtp.mailfrom=gmalecha AT gmail.com; spf=None smtp.helo=postmaster AT mail-yk0-f180.google.com
- Ironport-phdr: 9a23:d05WdBxyh5ZolNTXCy+O+j09IxM/srCxBDY+r6Qd0e0WIJqq85mqBkHD//Il1AaPBtWGraIfwLeM+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU35/8irr60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGx48sgs/M9YUKj8Y79wDfkBVGxnYCgJ45jAsgCLZg+S7DNIWWIP1xFMHgLt7RfgX563vDGs5cRn3yzPEtf7QrcuSHyH5qNmQx/hwHMIMjc9/WrXg+R/iatapFSqoBkpkN2cW52cKPcrJvCVRtgdX2cUG58JDyE=
This is great. Thanks, Matthieu. I should have looked at the new documentation.
On Thu, Nov 26, 2015 at 3:47 AM, Matthieu Sozeau <mattam AT mattam.org> wrote:
Hi Gregory,if you put yourself in Universe Polymorphism mode or prefix the following Universes command with [Polymorphic] you can get what you expect:Section pmap.Polymorphic Universes i j.Variable T : Type@{i}.Variable U : Type@{j}.Variable f : T -> U.Polymorphic Fixpoint pmap (ls : plist@{i} T) : plist@{j} U :=match ls with| pnil => pnil| pcons l ls => pcons (f l) (pmap ls)end.End pmap.pmap@{Top.105 Top.106} :forall (T : Type@{Top.105}) (U : Type@{Top.106}),(T -> U) -> plist@{Top.105} T -> plist@{Top.106} U(* Top.105 Top.106 |= Set <= Top.105Set <= Top.106*)This is all documented in the reference manual.Best,-- MatthieuOn Wed, Nov 25, 2015 at 8:41 AM Gregory Malecha <gmalecha AT gmail.com> wrote:Hello --I've been playing with the new universe polymorphism code in 8.5 and it is great, but I'm wondering if there is any way to declare a universe in a section and have them "cooked" at the end?Thanks a lot.Here is a concrete example. Suppose that I have polymorphic lists.Set Printing Universes.Polymorphic Inductive plist@{i} (T : Type@{i}) : Type@{i} :=| pnil| pcons : T -> plist T -> plist T.Arguments pnil {_}.Arguments pcons {_} _ _.And I'd like to write the polymorphic map function. Normally (without polymorphism) I would use sections like this since the termination checker does better with this:Section pmap.Variable T : Type.Variable U : Type.Variable f : T -> U.Polymorphic Fixpoint pmap (ls : plist T) : plist U :=match ls with| pnil => pnil| pcons l ls => pcons (f l) (pmap ls)end.End pmap.However, this gives me a quite strange definition.About pmap.(*pmap@{Top.9 Top.13} :forall (T : Type@{Top.7}) (U : Type@{Top.8}),(T -> U) -> plist@{Top.9} T -> plist@{Top.13} U(* Top.9 Top.13 |= Set <= Top.9Set <= Top.13Top.7 <= Top.9Top.8 <= Top.13*)*)What I'd like to get is something like this:Polymorphic Definition pmap'@{i j} {T : Type@{i}} {U : Type@{j}} (f : T -> U): plist@{i} T -> plist@{j} U :=fix pmap ls :=match ls with| pnil => pnil| pcons l ls => pcons (f l) (pmap ls)end.Which has exactly the definition that I want.About pmap'.(*pmap'@{i j} :forall (T : Type@{i}) (U : Type@{j}), (T -> U) -> plist@{i} T -> plist@{j} U(* i j |= Set <= iSet <= j*)pmap' is universe polymorphicArguments T, U are implicit and maximally insertedArgument scopes are [type_scope type_scope _ _]pmap' is transparentExpands to: Constant Top.pmap'*)Unfortunately, it can be quite annoying to write a bunch of functions out like this explicitly. The problem seems to come from the inability to name the universes in the types of T and U and continue using them later in the section.--gregory malecha
gregory malecha
- [Coq-Club] Local Universes in Sections?, Gregory Malecha, 11/25/2015
- Re: [Coq-Club] Local Universes in Sections?, Chan Ngo, 11/25/2015
- Re: [Coq-Club] Local Universes in Sections?, Matthieu Sozeau, 11/26/2015
- Re: [Coq-Club] Local Universes in Sections?, Gregory Malecha, 11/27/2015
