- From: gallego AT cri.ensmp.fr (Emilio Jesús Gallego Arias)
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Decidability of Propositional Logic
- Date: Sun, 29 Nov 2015 02:40:11 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gallego AT cri.ensmp.fr; spf=Pass smtp.mailfrom=gsmlcc-coq-club AT m.gmane.org; spf=Pass smtp.helo=postmaster AT plane.gmane.org
- Cancel-lock: sha1:a68+DUGLpf74F27CZR8/xy07weM=
- Ironport-phdr: 9a23:HlBSuRYM4GLn4KBImblY9Uf/LSx+4OfEezUN459isYplN5qZpcm4bnLW6fgltlLVR4KTs6sC0LqL9fC9EjVfu96oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvc2OKFwX3nKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzAZmx5MDgfCxBrgX9H8tDD/rqxzwmHaEMj3SbEzERav9DVwADDhjCMKODlx2XvWg9cx3/ETmw6ouxEqm92cW4qSLvcrJq4=
Hello Jeffrey,
"Terrell, Jeffrey"
<jeffrey.terrell AT kcl.ac.uk>
writes:
> Does anyone know of a Coq proof that propositional logic is decidable?
If you are looking for a more compact solution you could just build an
interpretation from propositional formulae to bool; decidability then
follows.
A quick example building such a function is attached below.
Best regards,
Emilio
Require Import ssreflect ssrfun ssrbool eqtype ssrnat fintype finfun.
Section PL.
Variable (n : nat).
Inductive PropF : Type :=
| Var of 'I_n
| Bot
| Conj of PropF & PropF
| Disj of PropF & PropF
| Impl of PropF & PropF
Definition inter (v : {ffun 'I_n -> bool}) :=
fix i p := match p with
| Var i => v i
| Bot => false
| Conj p1 p2 => i p1 && i p2
| Disj p1 p2 => i p1 || i p2
| Impl p1 p2 => i p1 ==> i p2
end.
Definition models (p : PropF) := [forall v, inter v p].
End PL.
About models.
(* models : forall n : nat, PropF n -> bool *)
- [Coq-Club] Decidability of Propositional Logic, Terrell, Jeffrey, 11/28/2015
- Re: [Coq-Club] Decidability of Propositional Logic, Julian Michael, 11/28/2015
- Re: [Coq-Club] Decidability of Propositional Logic, Emilio Jesús Gallego Arias, 11/29/2015
- Re: [Coq-Club] Decidability of Propositional Logic, Daniel Schepler, 11/29/2015
- Re: [Coq-Club] Decidability of Propositional Logic, Julian Michael, 11/29/2015
- Re: [Coq-Club] Decidability of Propositional Logic, Gabriel Scherer, 11/29/2015
- Re: [Coq-Club] Decidability of Propositional Logic, Gert Smolka, 11/29/2015
