coq-club - Re: [Coq-Club] Decidability of Propositional Logic
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Decidability of Propositional Logic
  • Date: Sat, 28 Nov 2015 18:04:46 -0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=dschepler AT gmail.com; spf=Pass smtp.mailfrom=dschepler AT gmail.com; spf=None smtp.helo=postmaster AT mail-pa0-f42.google.com
  • Ironport-phdr: 9a23:ixXnux/4RmGSkv9uRHKM819IXTAuvvDOBiVQ1KB91+ocTK2v8tzYMVDF4r011RmSDdidu68P0rWL+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU35n8jr/vs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCeG4HoRVi0tmRpFGwzI9lmuUoz6sibisudn8CafNMzyC7szXGLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
On Sunday, November 29, 2015 02:40:11 AM Emilio Jesús Gallego Arias wrote:
> Hello Jeffrey,
> "Terrell, Jeffrey"
> <jeffrey.terrell AT kcl.ac.uk>
> writes:
> > Does anyone know of a Coq proof that propositional logic is decidable?
> If you are looking for a more compact solution you could just build an
> interpretation from propositional formulae to bool; decidability then
> follows.
> A quick example building such a function is attached below.
I read the question as being about proving the decidability of whether some
context proves a certain proposition in some formal system representing
intuitionstic propositional logic - or equivalently, the decidability of
whether some given formula is a theorem (axiom-free) in the system. So, for
example, along the lines of what the Coq "tauto" tactic does based on the
LJT*
system.
I've recently played around with some development along those lines -
defining
a natural deduction style proof system in Coq, and proving that it results in
a free Heyting algebra. I haven't defined a decision procedure for it, much
less proved the completeness - which essentially reduces to cut elimination,
or perhaps as another way of putting it the possibility of reducing a lambda
expression representation of a proof to a normal form. Unfortunately, it's
on
another machine I wouldn't be able to access until Monday, if you'd be
interested in seeing what I have so far.
Daniel Schepler
