Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n"
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n"
- Date: Tue, 1 Dec 2015 09:44:01 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=stolz AT ifi.uio.no; spf=None smtp.mailfrom=stolz AT ifi.uio.no; spf=None smtp.helo=postmaster AT mail-out5.uio.no
- Ironport-phdr: 9a23:AKJd3BIV4Qd4q9uzi9mcpTZWNBhigK39O0sv0rFitYgUKfjxwZ3uMQTl6Ol3ixeRBMOAu68C27ud6vmwEUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35nxh7H5osSDKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs0UbVmYbiFJzHw/B/lmuRYv2tjnSt+R8njSbOovwSuZnCnyZ8653RUqw2288PDkj/TSPhw==
Dear Laurent, dear Amin, thank you for your answers -- unfortunately
they both seem to subvert the spirit of my original problem :-)
So here is my actual problem:
PF is a representation of propositional formulae bool
True/False, props of some type, and negation on disjunction to build
terms. That is, I have terms as a tree structure.
Section PF.
Variable A : Set.
Inductive pf : Type :=
| bT : pf
| bF : pf
| p (a:A) : pf
| neg (phi:pf) : pf
| or (phi psi: pf) : pf.
Require Import Ensembles.
Require Import Finite_sets.
Require Import Finite_sets_facts.
Fixpoint sf phi : Ensemble pf :=
match phi with
| bT => Singleton pf bT
| bF => Singleton _ bF
| p x => Singleton _ (p x)
| neg phi' => Add _ (sf phi') phi
| or phi' psi' => Add _ (Union _ (sf phi') (sf psi')) phi
end.
And here is my problematic property:
Hypothesis negNotInSelf: forall phi, ~In _ (sf phi) (neg phi).
I.e. sf bT := {bT}, and it does not contain (neg bT). I would hope that
once I've figured that out, the "or" (binary) case would work
analogously. I also tried some variations along the lines of not just
(neg phi), but anything "larger", but didn't have any success with the
formulation.
Best, Volker
- Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n", Volker Stolz, 12/01/2015
- Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n", Dominique Larchey-Wendling, 12/01/2015
- Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n", Volker Stolz, 12/02/2015
- <Possible follow-up(s)>
- Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n", Laurent Thery, 12/01/2015
