coq-club - Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n"
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Problem proving "no number larger than n is in the subset of numbers up to n"
  • Date: Tue, 1 Dec 2015 23:48:40 +0100 (CET)
----- Mail original -----
> De: "Volker Stolz"
> <stolz AT ifi.uio.no>
> À:
> Envoyé: Mardi 1 Décembre 2015 09:44:01
> Objet: Re: [Coq-Club] Problem proving "no number larger than n is in the
> Dear Laurent, dear Amin, thank you for your answers -- unfortunately
> they both seem to subvert the spirit of my original problem :-)
> So here is my actual problem:
> PF is a representation of propositional formulae bool
> True/False, props of some type, and negation on disjunction to build
> terms. That is, I have terms as a tree structure.
> Section PF.
> Variable A : Set.
> Inductive pf : Type :=
> | bT : pf
> | bF : pf
> | p (a:A) : pf
> | neg (phi:pf) : pf
> | or (phi psi: pf) : pf.
> Require Import Ensembles.
> Require Import Finite_sets.
> Require Import Finite_sets_facts.
> Fixpoint sf phi : Ensemble pf :=
> match phi with
> | bT => Singleton pf bT
> | bF => Singleton _ bF
> | p x => Singleton _ (p x)
> | neg phi' => Add _ (sf phi') phi
> | or phi' psi' => Add _ (Union _ (sf phi') (sf psi')) phi
> end.
> And here is my problematic property:
> Hypothesis negNotInSelf: forall phi, ~In _ (sf phi) (neg phi).
A way to do this is to strengthen the property so that it can be proved
easily inductively. For instance:
1/ define pf_size as a Fixpoint measuring the size of a formula in pf.
pf_size : pf -> nat
2/ Then show that any subformula of phi (x s.t. In _ (sf phi) x)
has a pf_size less than that of phi. This is an *easy* inductive proof
on phi (use the omega tactic if you are lazy solving the inequations
between elements of nat).
forall phi x, In _ (sf phi) x -> pf_size x <= pf_size phi
3/ Finally, show that the pf_size of neg phi is not less than that of phi
which should hold for any reasonable definition of pf_size.
forall phi, ~ (pf_size (neg phi) <= pf_size phi)
4/ conclude
Remark that you can replace pf_size by pf_height. There are certainly
numerous other options.
Best,
Dominique
