- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Co-inductive Streams vs. Functions
- Date: Tue, 8 Dec 2015 00:41:29 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=arnaud.spiwack AT gmail.com; spf=Pass smtp.mailfrom=arnaud.spiwack AT gmail.com; spf=None smtp.helo=postmaster AT mail-lf0-f46.google.com
- Ironport-phdr: 9a23:PtMNaBLkyAjKorfapNmcpTZWNBhigK39O0sv0rFitYgUIvzxwZ3uMQTl6Ol3ixeRBMOAu6wC0rCd6vuocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0YLujavroNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD89pozcNLUL37cqIkVvQYSW1+ayFmrPHs4DLEVEOk4mYWGjEdlQMNCAzY5jn7WI3wu230rLwu9jOdOJjfV7Y9RDjq1L9qVxbji29TPiUh8X7egc9YiKNL5gqmow1jzoXUZoCMKfc4cLmLLoBSfnZIQssED38JOYi7dYZaSrNZZes=
Up to mild extensionality predicates, your two types are isomorphic. You may enjoy verifying that.
On 7 December 2015 at 20:06, Gregory Malecha <gmalecha AT gmail.com> wrote:
Thanks, Pierre-Marie --At the moment I just prove that this are [Proper], which isn't really too big of a problem since you can define combinators that handle the properness proofs for the most part. I guess I'm wondering more from a model point of view, are there any corner cases that one definition covers that the other does not?If the co-inductive lists could also be finite, i.e. with this definitionCoInductive ftrace (st : Type) : Type :=| Cons : st -> ftrace st -> ftrace st| Done.Then with functions you need to add some notion of "equal up to the occurrence of 'Done'" which is a bit cumbersome to express. But it seems that for truly infinite, non-dependent structures you might always be able to play this trick of "functions from paths to values". Is that the case, or is there a reason to prefer the CoInductive definition?--On Mon, Dec 7, 2015 at 10:48 AM, Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr> wrote:On 07/12/2015 19:11, Gregory Malecha wrote:
> To reason about the first I use co-induction and I do not need
> functional extensionality.
You'll actually need some form of extensionality to use it with ease.
Indeed, you cannot disprove the following in Coq, and it's pretty useful
in practical use:
CoInductive trace (state : Type) : Type :=
| Cons : state -> trace state -> trace state.
CoInductive bisimilar {state} : trace state -> trace state -> Prop :=
| Bisimilar : forall s t1 t2, bisimilar t1 t2 -> bisimilar (Cons _ s t1)
(Cons _ s t2).
Axiom trace_extensionality : forall state (t1 t2 : trace state),
bisimilar t1 t2 -> t1 = t2.
If you don't assume it, you'll have to show that all of your predicates
are Proper (and they meta-are), just like for the functional case.
PMP
gregory malecha
- [Coq-Club] Co-inductive Streams vs. Functions, Gregory Malecha, 12/07/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Pierre-Marie Pédrot, 12/07/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Gregory Malecha, 12/07/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Arnaud Spiwack, 12/08/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Eddy Westbrook, 12/10/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Thorsten Altenkirch, 12/10/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Daniel Schepler, 12/10/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Eddy Westbrook, 12/11/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Benedikt Ahrens, 12/12/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Gregory Malecha, 12/11/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Emilio Jesús Gallego Arias, 12/11/2015
- <Possible follow-up(s)>
- Re: [Coq-Club] Co-inductive Streams vs. Functions, CJ Bell, 12/10/2015
