- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Co-inductive Streams vs. Functions
- Date: Thu, 10 Dec 2015 08:21:20 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=westbrook AT kestrel.edu; spf=None smtp.mailfrom=westbrook AT kestrel.edu; spf=None smtp.helo=postmaster AT mail.kestrel.edu
- Ironport-phdr: 9a23:I3zjMhFxJHq9v3nmE4id751GYnF86YWxBRYc798ds5kLTJ75pMWwAkXT6L1XgUPTWs2DsrQf27SQ6v+rCTBIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niabrpNaDP01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4xXmkH2iVFGBTP9hb9Xd+lrSbhquBn3y6ZFc77VqwuVDDk4qt2Hky7wBwbPiI0pTmEwvd7i7hW9Uqs
Hi Greg,
I have actually thought a lot recently about modeling non-terminating systems, and have mostly come to a similar conclusion as you, that (nat-> A) equivalent to (Stream A), and that the former does not require co-inductive types (which I don't like for a number of theoretical and practical reasons).
Adam has actually defined a non-termination monad based upon this idea, which you can find if you google for "non-termination monad" (or you can probably just ask him). If you are interested, I was also working on a non-termination monad transformer a few months ago, that adds a similar notion of non-termination to any monad, and I can send it to you if you are interested.
-Eddy
Sent from my iPhone
Sent from my iPhone
Thanks, Pierre-Marie --At the moment I just prove that this are [Proper], which isn't really too big of a problem since you can define combinators that handle the properness proofs for the most part. I guess I'm wondering more from a model point of view, are there any corner cases that one definition covers that the other does not?If the co-inductive lists could also be finite, i.e. with this definitionCoInductive ftrace (st : Type) : Type :=| Cons : st -> ftrace st -> ftrace st| Done.Then with functions you need to add some notion of "equal up to the occurrence of 'Done'" which is a bit cumbersome to express. But it seems that for truly infinite, non-dependent structures you might always be able to play this trick of "functions from paths to values". Is that the case, or is there a reason to prefer the CoInductive definition?On Mon, Dec 7, 2015 at 10:48 AM, Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr> wrote:On 07/12/2015 19:11, Gregory Malecha wrote:
> To reason about the first I use co-induction and I do not need
> functional extensionality.
You'll actually need some form of extensionality to use it with ease.
Indeed, you cannot disprove the following in Coq, and it's pretty useful
in practical use:
CoInductive trace (state : Type) : Type :=
| Cons : state -> trace state -> trace state.
CoInductive bisimilar {state} : trace state -> trace state -> Prop :=
| Bisimilar : forall s t1 t2, bisimilar t1 t2 -> bisimilar (Cons _ s t1)
(Cons _ s t2).
Axiom trace_extensionality : forall state (t1 t2 : trace state),
bisimilar t1 t2 -> t1 = t2.
If you don't assume it, you'll have to show that all of your predicates
are Proper (and they meta-are), just like for the functional case.
PMP
--gregory malecha
- [Coq-Club] Co-inductive Streams vs. Functions, Gregory Malecha, 12/07/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Pierre-Marie Pédrot, 12/07/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Gregory Malecha, 12/07/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Arnaud Spiwack, 12/08/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Eddy Westbrook, 12/10/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Thorsten Altenkirch, 12/10/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Daniel Schepler, 12/10/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Eddy Westbrook, 12/11/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Benedikt Ahrens, 12/12/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Gregory Malecha, 12/11/2015
- Re: [Coq-Club] Co-inductive Streams vs. Functions, Emilio Jesús Gallego Arias, 12/11/2015
- <Possible follow-up(s)>
- Re: [Coq-Club] Co-inductive Streams vs. Functions, CJ Bell, 12/10/2015
