coq-club - Re: [Coq-Club] Bounding the Type Hierarchy
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Bounding the Type Hierarchy
  • Date: Thu, 10 Dec 2015 13:51:53 +0100
  • Organization: LORIA
Thank you for your suggestion Guillaume.
> Print Sorted Universes "universes.txt".
Reading the generated file, I remark that there
are two kinds of informations:
1/ order constraints like Type.{n} < Type.{n+1}
2/ identity constraints like {path}.{number} = Type.{n}
I have some questions.
a/ what does the {number} mean ? An occurrence in the source code ?
b/ if Type.2 is the greatest Type.{n} that occurs in the list of
constraints, can I deduce that all the loaded theorems can be
proved in a restriction of the CIC with a Type hierarchy equal
to
Prop < Type.0 < Type.1 < Type.2
c/ After Cedric Auger's message, I am a bit confused. It seemed to
me that CIC was equal to the limit \bigcup_n CIC(n) where
CIC(n) is the restriction of the CIC where n bounds the highest
level in the Type hierarchy. It seems (but may be I did not
understand well) that Cedric suggests that CIC(n) might even
be inconsistent ? In which case, the questions I am asking
could be found odd.
Dominique
On 12/08/2015 05:04 PM, Guillaume Melquiond wrote:> On 08/12/2015 15:59,
Robbert Krebbers wrote:
>> On 12/08/2015 03:54 PM, Dominique Larchey-Wendling wrote:
>>> Another way to formulate the question is how can I know the maximum
>>> n such that Type_n is needed in the type-checking of a given proof ?
>> Maybe "Print Sorted Universes" will help. From the reference manual:
>> If the optional Sorted option is given, each universe will
>> be made equivalent to a numbered label reflecting its level
>> (with a linear ordering) in the universe hierarchy.
> Yes, that is the way to do it. For instance, Coq's testsuite executes
> the following script:
> Require all_stdlib.
> Then it parses the generated file to check that the number of universe
> levels needed to typecheck the standard library did not unexpectedly
change.
> Best regards,
> Guillaume
