coq-club - Re: [Coq-Club] Universe Polymorphic Relations
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Universe Polymorphic Relations
  • Date: Wed, 23 Dec 2015 13:52:24 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f182.google.com
  • Ironport-phdr: 9a23:ePdnOBwFtmcUoWzXCy+O+j09IxM/srCxBDY+r6Qd0e4XIJqq85mqBkHD//Il1AaPBtWFraocw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwudrqzQtaapv/0/t7x0qWbWx9Piju5bOE6BzSNhiKViPMrh5B/IL060BrDrygAUe1XwWR1OQDbxE6ktY/jtKJkpi9Xorcq89NKGfHxeL19RrhFBhwnNXo07Yvlr0+QYxGI4y4+W34RlFJnGQ/e91muXJ7qtS31rO1mw3iyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
I think you are looking for Coq.Classes.CRelationClasses.
On Wed, Dec 23, 2015 at 12:50 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:
Hello --
I'm wondering if there are definitions analagous to [Reflexive] and [Transitive] that are both universe polymorphic and work with the built-in tactics such as [reflexivity] and setoid rewriting. In particular, I note that when I use the basic definitions I get a universe constraint that I would like to avoid. For example,
Require Import Coq.Classes.RelationClasses.
Set Printing Universes.
Polymorphic Class ILogic (T : Type) : Type :=
{ lentails : T -> T -> Prop
; Refl_lentails : Reflexive lentails }.
Print ILogic.
Polymorphic Record ILogic (T : Type@{Top.1}) : Type@{max(Set+1, Top.1)}
  := Build_ILogic
  { lentails : T -> T -> Prop;  Refl_lentails : Reflexive lentails }
(* Top.1 |= Top.1 <= Coq.Classes.RelationClasses.1
The extra constraint [Top.1 <= Coq.Classes.RelationClasses.1] makes this definition less useful in my particular context. If I inline the definition of [Reflexive] then everything works out.
Polymorphic Class ILogic' (T : Type) : Type :=
{ lentails' : T -> T -> Prop
; Refl_lentails' :> forall a : T, lentails' a a }.
Print ILogic'.
Polymorphic Record ILogic' (T : Type@{Top.12}) : Type@{max(Set+1, Top.12)}
  := Build_ILogic'
  { lentails' : T -> T -> Prop;  Refl_lentails' : forall a : T, lentails' a a }
(* Top.12 |=  *)
However, with this definition, [reflexivity] does not work. I'm wondering if there already exists polymorphic instances of the basic classes, e.g. [Reflexive], [Transitive], [Proper], [Respectful], etc, or if there is some way to tell Coq to look for instances of a polymorphic version of these classes that I would define.
Thanks so much.
gregory malecha
