- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Universe Polymorphic Relations
- Date: Wed, 23 Dec 2015 14:38:19 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f44.google.com
- Ironport-phdr: 9a23:YQUVBxQBlPdYjLrm2QbOp+Zg3dpsv+yvbD5Q0YIujvd0So/mwa64YBWN2/xhgRfzUJnB7Loc0qyN4/6mATRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niabqo9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULYQWD8hKiU+4NDhnRjFVwqGoHUGBDY4iB1NVirM9xb8FrjrtTDh/r5/0TKdO8LsSqsvCByt6q5qTFnjjyJRZG1xy33elsEl1PETmxmmvREqm4M=
Maybe [reflexivity] doesn't support CRelationClasses? You can do
Ltac reflexivity :=
first [ Coq.Init.Notations.reflexivity
| intros; exact (@Coq.Classes.CRelationClasses.reflexivity _ _ _ _) ]
|| Coq.Init.Notations.reflexivity.
to work around this. (The "|| Coq.Init.Notations.reflexivity" is just to get back the error messages of [reflexivity].)
On Wed, Dec 23, 2015 at 2:16 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:
It looks like I spoke a bit too soon. What do I need to include in order to make it work with [reflexivity]?Require Import Setoid.Require Import Coq.Classes.CRelationClasses.Set Printing Universes.Polymorphic Class ILogic@{U X} (T : Type@{U}) : Type :={ lentails : T -> T -> Prop; Refl_lentails :> Reflexive@{U X} lentails }.Existing Instance Refl_lentails.Print ILogic.Section foo.Universe U T.Variable T : Type@{T}.Variable ILT : ILogic@{T U} T.Existing Instance ILT.Goal forall x : T, lentails x x.intros.reflexivity.(* Error: Tactic failure: The relation lentails@{TU} is not a declared reflexive relation. Maybe you need to require the Setoid library.*)eapply Refl_lentails. (* WORKS *)Is this a bug with [eauto] and universe polymorphic lemmas?--On Wed, Dec 23, 2015 at 11:09 AM, Gregory Malecha <gmalecha AT gmail.com> wrote:Yup. I believe that is what I'm looking for. Unfortunately, the online documentation does not show universes, so it pretty much looks the same as RelationClasses. ;-)Thanks.--On Wed, Dec 23, 2015 at 10:52 AM, Jason Gross <jasongross9 AT gmail.com> wrote:I think you are looking for Coq.Classes.CRelationClasses.On Wed, Dec 23, 2015 at 12:50 PM, Gregory Malecha <gmalecha AT gmail.com> wrote:Hello --I'm wondering if there are definitions analagous to [Reflexive] and [Transitive] that are both universe polymorphic and work with the built-in tactics such as [reflexivity] and setoid rewriting. In particular, I note that when I use the basic definitions I get a universe constraint that I would like to avoid. For example,Require Import Coq.Classes.RelationClasses.Set Printing Universes.Polymorphic Class ILogic (T : Type) : Type :={ lentails : T -> T -> Prop; Refl_lentails : Reflexive lentails }.Print ILogic.(*Polymorphic Record ILogic (T : Type@{Top.1}) : Type@{max(Set+1, Top.1)}:= Build_ILogic{ lentails : T -> T -> Prop; Refl_lentails : Reflexive lentails }(* Top.1 |= Top.1 <= Coq.Classes.RelationClasses.1*)*)The extra constraint [Top.1 <= Coq.Classes.RelationClasses.1] makes this definition less useful in my particular context. If I inline the definition of [Reflexive] then everything works out.Polymorphic Class ILogic' (T : Type) : Type :={ lentails' : T -> T -> Prop; Refl_lentails' :> forall a : T, lentails' a a }.Print ILogic'.(*Polymorphic Record ILogic' (T : Type@{Top.12}) : Type@{max(Set+1, Top.12)}:= Build_ILogic'{ lentails' : T -> T -> Prop; Refl_lentails' : forall a : T, lentails' a a }(* Top.12 |= *)*)However, with this definition, [reflexivity] does not work. I'm wondering if there already exists polymorphic instances of the basic classes, e.g. [Reflexive], [Transitive], [Proper], [Respectful], etc, or if there is some way to tell Coq to look for instances of a polymorphic version of these classes that I would define.Thanks so much.--gregory malechagregory malechagregory malecha
- [Coq-Club] Universe Polymorphic Relations, Gregory Malecha, 12/23/2015
- Re: [Coq-Club] Universe Polymorphic Relations, Jason Gross, 12/23/2015
- Re: [Coq-Club] Universe Polymorphic Relations, Gregory Malecha, 12/23/2015
