coq-club - Re: [Coq-Club] VST release 1.6
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] VST release 1.6
  • Date: Mon, 4 Jan 2016 10:29:13 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=adamc AT csail.mit.edu; spf=Pass smtp.mailfrom=adamc AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing.csail.mit.edu
  • Ironport-phdr: 9a23:Ksl21x2hpfTdVixlsmDT+DRfVm0co7zxezQtwd8ZsegVKvad9pjvdHbS+e9qxAeQG96LtbQc06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL2PbrnD61zMOABK3bVMzfbSrXNaKx+2MlMmMuLTrKz1SgzS8Zb4gZD6Xli728vcsvI15N6wqwQHIqHYbM85fxGdvOE7B102kvpT4r9Zf9HFbvOtk/MpdW437eb45RPpWFmcIKWcwseTnvByLZguL52MVVmxexhNECg3OxBrhV5b19C77qqxw1DTMbp6+dqw9RTn3t/QjcxTvkipSbzM=
On 01/04/2016 10:21 AM, Chan Ngo wrote:
On Jan 4, 2016, at 4:03 PM, Adam Chlipala
<adamc AT csail.mit.edu>
wrote:
On 01/04/2016 04:23 AM, Chan Ngo wrote:
On Jan 4, 2016, at 9:55 AM, Claude Marché
<Claude.Marche AT inria.fr>
wrote:
So, in short:
VST: specification language = Coq, back-end prover = Coq
Frama-C/Why3: specification language = ACSL, back-end provers = SMT solvers
VST provides a much higher level of trust than the latter, thanks to the
use of CompCert. There was an attempt to design a Frama-C deductive
verification plugin of Frama-C through CompCert (PhD thesis of Paolo
Hemrs, https://tel.archives-ouvertes.fr/tel-00789543) but it did not
make its way to a robust, distributed plug-in.
I think that if we can certify the automated provers used in that tools, we
can obtain the same formal level of trust as providing by VST. It is the same
as some additional parts of the CompCert compiler which use translation
validation approach (produce a validator), meaning that if we certify the
validator formally then the result validated compiler is the same level of
trust as the formal verified compiler.
I'm afraid that description is rather far from accurate, if by "automated provers" you
mean "SMT solvers." Frama-C has much trusted code having to do with the C language and
associated verification methodologies. All of that code would need to be certified/certifying,
too, not just the SMT solvers. Compared to proof witnesses from SMT solvers, which are
relatively well-understood today, it's not as obvious how to use proof-generating translations to
handle the semantics of C or the application of a verification methodology.
Yes, thanks for reminding that. Somehow I assumed that the correctness of the
tool’s development (i.e., Frama-C). Since I want to emphasize the use of
external libs. Consider a deductive verification proof from VST and the proof
from tools like Why3, Frama-C for a same specification, how we can say that
these two proofs are the same level of trust? I would like to say if the can
prove the correctness of the later tools development (including the tool
itself and the external libs), we can guarantee the same level of trust,
please correct me if it is not so (As the example of the validator in
complier validation does so according the claims in some work of Leroy in
CompCert project)..
Well, there are some subtleties. The approximate answer is that, yes, with proofs of correctness for all the Frama-C tools, you would reach the same level of trust as VST. However, it would be important that all the proofs are implemented in Coq, in a way that allows them to be linked together within Coq in the usual way.
It would be a huge job to make Frama-C and its deductive plugin certified or certifying. Quite likely it would require implementation changes to both. That is, I'd be willing to bet money that both Frama-C and its deductive plugin have significant soundness bugs today, just because it's hard to be bug-free without formal certification.
