coq-club - Re: [Coq-Club] Accessing Class members
  • From: Durward McDonell <Durward.McDonell AT jhuapl.edu>
  • To: <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Accessing Class members
  • Date: Tue, 12 Jan 2016 11:58:10 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Durward.McDonell AT jhuapl.edu; spf=Pass smtp.mailfrom=Durward.McDonell AT jhuapl.edu; spf=Pass smtp.helo=postmaster AT pilot.jhuapl.edu
  • Ironport-phdr: 9a23:LAMbwR25E8RPDKXTsmDT+DRfVm0co7zxezQtwd8ZsegSI/ad9pjvdHbS+e9qxAeQG96LtbQU1qGP4+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6MyZTqnLnis7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JsUWqLjOq88ULZwDTI8Mmlz6te95jfZSg7aymYGTWwMnlJtCCTC6hz+Wt+lnjbgqeNn1G+/NuHxS70wXRyg77piUBuuhSsaYW1quFrLg9B92foI6CmqoAZyltbZ
I should have posted a working foo.v. Here it is:
Require Import ZModulo.
Require Import ZArith.
Require Import DoubleType.
Require Import CyclicAxioms.
Set Implicit Arguments.
Open Scope positive_scope.
Module PNO : PositiveNotOne.
Definition p := 3.
Lemma not_one : p <> 1%positive.
Proof.
unfold p.
discriminate.
Qed.
End PNO.
Close Scope positive_scope.
Open Scope Z_scope.
Module ZMCT <: CyclicType := ZModuloCyclicType PNO.
At this point, ZMCT.t, ZMCT.ops, and ZMCT.specs will all happily let
you Print their types, but you cannot access any of the members of
ZMCT.ops or ZMCT.specs, as far as I can tell.
Durward McDonell
durward.mcdonell AT jhuapl.edu
240-228-2690 (DC)
443-778-2690 (Balt.)
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
